Results 1 to 40 of 46
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Snub Mounts? What the difference?
    I have no idea what a snub mount does... I have seen on sites like ECS all these different type of mounts... Some priced higher than other. What is the difference (other than color b/c Audi's OEM is blk and APR is red) is it worth the difference in price?? What will I get/gain from buying aftermarket?
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Re: Snub Mounts? What the difference?
    The stiffer aftermarket snub mounts take up extra slack in the drivetrain reducing driveline shock and making power transfer smoother.
    Feb 27 2008
    I saw a similar explanation on ECS... What does that mean in english?
    Jul 04 2008
    York, PA
    The stock snub mount is soft and spongy so when compressed it gives and adds slack to the drivetrain. When a stiffer snub mount goes in it doesn't give and takes up that extra slack.
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    i heard greddy snub ≥ APR snub....is that true???
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    id choose apr...leave greddy to the Hondas
    Jul 04 2008
    York, PA
    APR makes good products but unfortunately their snub mount is known to break.
    http://www.audizine.com/forum/showth...light=apr+snub
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    The snub mount is the forward most engine mount. A stiffer version, like our APR or Stern mounts reduces engine movement over stock. It makes shifting a little easier, and makes the car feel a bit more solid since the engine isn't moving around as much.
    Differences between the various brands are all pretty small, APR, Stern, Neuspeed, Apikol, all have some minor geometry and materials changes.
    We carry both the APR and Stern brands with great results from both.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    ^^^ Listen to him APR snubs do NOT have a good track record... From someone that has some of their other stuff.
    My Apikol snub from 034Motorsport is terrific so far.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Established Member Two Rings afozzie40's Avatar
    Oct 21 2008
    B6 A4 1.8T
    Boulder, Colorado
    I just ordered an ECS snub. I also heard APR breaks B/C of material. Apikol is also good so i've heard.
    03 B6 MT Sport suspension 15% Tint Custom Magnaflow exhaust K&N Stock Air Box Mod ECS Snub
    Senior Member Two Rings mtxsho93's Avatar
    Sep 20 2008
    93 SHO, 02 A6 2.7T 6MT
    South Jersey
    I thought that I read somewhere on here that there is a mount available with a cage bracket to hold it in place better than the factory mount. Am I making this up or does such a thing exist?
    If so, is it any better than just replacing the factory snub?
    Ian
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    What's the cost of the snub mount?
    What's the installation like?
    And, from people who already have it, do you like it?
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Dec 06 2007
    i just ordered a neuspeed, saty clear of APR's.
    -Kirk
    BetaAlphaTau Member #58
    May 13 2008
    NoCal - EBay
    Quote Originally Posted by mtxsho93 View Post
    Ian
    034Motorsport makes one but it is for the B5. They installed my snub and didn't use it. Although it is listed on their site it is not obvious how it would be utilized in the B6.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Neuspeed are by far the best.
    High speed Ferrari movement...
    Jul 04 2008
    York, PA
    Quote Originally Posted by tamaneri View Post
    $25-45
    Simple, there is a DIY around here somewhere.
    Yes
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    i have an apr and had no problems
    my friend has a nuespeed and has no problems, i think if you dont run a belly pan and i think its climate induced; meaning more salt = more corrosion on the rubber snub mount its going to fall apart quicker
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    Apr 02 2007
    Thanks for the info
    I guess I'll pick one up this spring!
    I need to put my belly pan back on. Winter is here!
    Taylor A. Maneri
    tamaneri (AIM)
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    I have a quick question.
    my car is auto tip.
    when it upshift/downshift, there's often a noticable vibration.
    is this the cause from snub mount?
    Sep 20 2008
    South Jersey
    Quote Originally Posted by A4SoftWalker View Post
    That's right! That's where I remembered seeing it. I'll have to check to see if it fits a C5. I have a new APR snub that I bought from ECS with their timing belt kit. Everything is still in boxes waiting for a free weekend...
    Ian
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    ****shit i meant greedspeed, not greddy.....what do you guys think of greedspeed????
    Feb 09 2008
    2002 A4 1.8T 5-speed
    Austin Texas
    Apikol. Very Easy install, i let my cat do it, and she doesnt have thumbs...
    When you guys nail it in your cars (without a new snub mount) and you hear a clunk, or when you shift thats the snub being a big OEM Pos.
    Capt. Obvious: It's like fucking your cousin, just because you can doesn't mean you should.
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    The stock snub mount is very soft and weak, allowing a lot of play on the longitudinal axis of the engine, which impresses load/tension on the rest of the drivetrain. The stiffer aftermarket units aren't nearly as sloppy, ranging from just a stiffer version of the stock parameter to some that full the forward mount cup, limiting almost all of the 'play'. This reduces drivetrain shift, improving the responsiveness of the car slightly, lowering the stress exerted on the other mounts and mounting points as well improving the precision of the shift gate due to the reduced play in the drivetrain.
    The APR unit is garbage in my opinion, I have only heard of two people to ever speak highly of this mount, while anyone else has had nothing but trouble. Mine lasted ~18,000mi, before I noticed it was destroyed, who knows how long before it initially started failing. The mount cracked in half and was working itself out of the mounting cup. The car became very sloppy and would randomly pop out of gear or completely refuse to go into gear at all. This mount is the most expensive as well at ~50$, which further makes me wonder WTF?!.
    Here is my APR snub:
    The Apikol and Sterm mounts are receiving good reviews here on Audizine, and considering that 034Motorsports supports Apikol, I have complete faith that it is a sound design.
    Personally, after my APR snub failed, I moved on to the Neuspeed unit. It fills the cup more completely and has reliefs in the parameter to help endure flex from the sidewall pressures when loaded. The design is the best and most unique in my opinion and the feel compared to the OEM or even the APR when it was new is stellar! Very firm and precise. There was a noticeable vibration at idle, only slight though and it isn't obnoxious or emitting any level noise. It softly permeates from the steering wheel and shift lever reminding you of the solidity of your drivetrain.
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Quote Originally Posted by Dopefish View Post
    i was actually gona go with APR...guess ill go with 034 or apikol.....
    Oct 15 2006
    From a few to one...
    Arlington, VA
    as much crap as apr gets, i've had the snub mount on for more than a year now, and no problems. it is still in good condition, w/ no cracks anywhere.
    love the shifting after it, don't think i can go back.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Neuspeed Snub mount is only $30 retail.
    CLICK
    I'm sure you could find it even cheaper at a reseller.
    I've had the neuspeed for 3.5 years. NOT A SINGLE sign of hesitation.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Established Member Two Rings Torqie's Avatar
    Jul 15 2007
    2003 A4 quattro 5 speed
    Salt Lake City, Utah
    Quote Originally Posted by A4 Moda View Post
    CLICK
    Just picked me up one.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    +1 on the Apikol Snub. I've had mine in for almost two years now and it's been through some of the most brutal winter conditions imaginable up in the mountains. over 11,000' in elevation in a blizzard, at lower than 0deg. temps! haha, bragging a bit about how awesome my audi is in extreme winter conditions! this snub is the shit though, drive train shock was drastically reduced after the install.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings QTC's Avatar
    Sep 16 2006
    2004 B6 A4 1.8t 6MT; 2013 F30 320i 6MT; 99.5 Pathfinder 4x4; Mk7 Golf TDI
    Wynnewood, PA
    I have a Stern snubmount (from purems). It was like $24 or something. Been great so far.
    Dahlback | AWE | Milltek | Vogtland | H-Sport | Oettinger | Thule | OEM+
    Apr 15 2008
    cke
    where did you guys get all these snub mounts from?
    so far all I searched is APR ones or ECSTuning's Snub mount.
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    have an Apikol snub on my tip B5 for about a month now, love it thus far!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    Quote Originally Posted by monkey323i View Post
    The first came straight from APR at a retarded $50 + shipping. The second was from Nuespeed at only $30, with FREE shipping. Nuespeed is for the win!
    Jun 11 2005
    Yup, for the whole 3.5 years i've ran the Neuspeed, I've had my bellypan off as well.
    Not a bad piece at all.
    2003 1.8T
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Apikol - love it.
    Here's my install thread.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Sep 20 2008
    South Jersey
    So which is generally the better mod; the drivetrain stabilizer brace or the snub mount? Or does it help out to run both together? Does anyone notice an increase in NVH with either the snub mount or DTS or a combination of both?
    Thanks,
    Ian
    Jul 19 2007
    San Diego, CA
    There is no DTS available for the B6 chassis I'm aware of.
    Apr 15 2008
    cke
    how is the Audi OEM snub mount?
    I'm planning to get this done ASAP and if Audi OEM snub mount is fine, then I guess I'm going to grab one tomrrow and get it installed right away.
    Jun 11 2005
    There's a lot of slack in it. It slops when you're trying to shift, especially during spirited driving.
    The choice is yours. I wouldn't do it though.
    2003 1.8T
    Apr 15 2008
    cke
    Hi:
    sry if this question is too dumb.
    but I just called in for snub mount, they said there're left and right side?
    so when you guys do the snub mount, you buy both sides (two snub mounts) ?
    how come in those DIY they only do right side only (passenger side).
    Apr 15 2008
    cke
    Hi:
    nvm, just found out that motor mount and snub mount are two different things.
