Lately my battery has been getting weak so I decided to replace it with a new one. So I drive the car home, replace the battery, charge it up and I start up the car and let it idle. As soon as I go to take it for a drive the car starts spurting and stalls. So now for the life of me I can't see why this is happening yet alone from a battery change so I put the old battery back in and have the same problem. Now I know it isn't the battery because that just makes no sense so I figure it has to be a coincidence. So now it hardly wants to idle at start and after a little while of giving it some gas it will smoothen out and idle like normal but as soon as you give it gas it wants to stall and often does. If you try and hold the gas pedal down it will rev up to wherever but as soon as it hits the RPM you are trying to hold it will immediately drop the revs back down like it is getting no fuel. Only previous related problem I can think of is when you put gas in the car as your pumping it the idle will go all weird and stop as soon as you're done. If you try and shut the car off while it pumps in when you go to start it up it will be a bitch to get it to crank over it will spin the flywheel and seem to not get enough gas and then eventually it will kick over.
