Results 1 to 40 of 54
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Next week's testing
    Fueling update...
    No fuel return (stick with the B6 style), no aftermarket parts...true datalogging.
    You guys will be amazed.
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Next week's testing
    aahah here we go
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Oct 22 2005
    Reppin the Mitten.
    Dun dun done.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    O boy...More Power!!
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings Tinman's Avatar
    Aug 25 2004
    nice n' low a-fo, 2006 Saaburu, 1978 Corvette
    Easton, PA
    yo greg, hit me back about the spoiler and pillars.
    L8
    ~ben
    no TURBO, no CARE.
    pics of the car: the original BB USP w/ gunmetal RS4s
    407awhp and 408awtq on a Mustang with 93oct and meth. still 1.8L
    GOT EFR? (543chp/544clb-ft)
    Jan 25 2006
    A4 2.0T
    MD
    So I guess as long as an OE manufacturer makes the part its not 'aftermarket' huh?
    I guess my garrett turbo and Bosch 044 pump are OEM also huh? *lol*
    Quote Originally Posted by Tinman View Post
    L8
    You are still alive huh?
    Where have you been.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    He is stating that he hasn't added any parts to his returnless fuel system other then what he already has in the car which is just a bosch fuel pump upgrade and injectors. Not all that hard to figure out seeing that a bunch of B6 owners feel that they need to do a B5 fuel system setup.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by Don Supreme View Post
    My interpretation of OEM is that if the part is in ETKA, it is not aftermarket. I can say OEM++ if you would like.
    Dec 14 2004
    Norway
    True datalogging? SEM?
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    only problem is that 71r turbo and 1.8 liter isnt gonna be able to make enough power comparable to say my car to see if the stock fuel system is a limitation. This testing needs to be on a car with a bigger turbo.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Not SEM but rather true datalogging tools that Eurocode has. The pump is going to be flow tested on the bench, then flow tested using our fuel line, then flow tested with the engine run to redline with multiple pulls.
    The pump we will be using is a TRUE drop in and there is no additional basket or hardware needed.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    That reminds me. I need to get my hands on some new data-logging software. VAG-Com can suck my.............
    I hate the slow sample rates. Need straight CAN-Bus sample rates...
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    apr ecux is fast and can do tons of logs at once. Think it is like $250 though.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings zemun2's Avatar
    Feb 20 2004
    '04 A4 1.8t FWD APR Tuned
    Zemun, Serbia.
    Quote Originally Posted by A4 TSCHUSS View Post
    And it also requires you to have APR software on the ECU, no worky with REVO or any other flashes
    APR Tuned Serbia
    Authorized APR Distributor
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by zemun2 View Post
    Really? I thought it pulled directly from the CAN-bus and is hard-coded to a particular ECU (profile file needed) since it calls certain locations on the ECU directly. Locations not specific to ECU software vendors (REVO, APR, etc..) but more specific to the Motronic system on that vehicle (ME 7, 7.5, 9.0, etc..).
    -Doug
    Apr 24 2005
    E55 AMG, CTS-V
    I though it worked on other software too. Pretty sure the guy who custom tunes at SSP Tuning uses it. And I know Mark uses it on his S4s, I thought it was on all of them, but maybe not.
    ~David~
    CTS-V 9.6@148
    Feb 20 2004
    Zemun, Serbia.
    It wouldn't work on my stage 3 REVO file and i called APR and they told me it can only be used with APR software.
    APR Tuned Serbia
    Feb 20 2004
    Zemun, Serbia.
    ECUX open specific high speed port that APR uses for comm, that's why it wont work with any other software, at least that's what Keith told me.
    Feel free to call him up.
    APR Tuned Serbia
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Maybe the B6 is different? I have seen ECUx logs from every tuner on a B5.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    I'm already amazed.
    But I'm waiting for Dave to come up with the Eurocode Complete solution #2 Fueling Upgrade .
    Keep up the good work Greg, Dave
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    NOt sure about B6, but it's usable on B5, stock or aftermarket ecu.
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Mar 19 2004
    Vegas
    What about ASP data log software?
    Cheers! David
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Will work however a profile needs to be built for the B6. Mark may have done it for Doug's Avant
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I'm glad to see that David is using that brain of his for the B6 now. Things are really going to start happening! Just look at Gregs last post. ~25AWHP gained by swapping a MAP, MAF, and injectors.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Silence View Post
    I will talk to Mark on Wednesday about it when I pick up my Avant. I keep forgetting to talk to him about it. He did make a profile to use with his software on the B6 A4 when he tuned my Avant.
    -Doug
    Dec 06 2007
    1/4 mile times or bust! i think u really have the capability to stomp on every record set, try and beat Charlie's record haha.
    -Kirk
    BetaAlphaTau Member #58
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by AudiA4Turbo22 View Post
    I know, come on Mike
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Weather permitting, I will be racing on Saturday the 27th
    Mar 21 2006
    Lakeland, FL.
    12.5x here you come!
    I'm back bitches!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Not likley...I make way too much torque for the clutch
    Veteran Member Four Rings traf818's Avatar
    North Hollywood
    I'm damn excited. I'll let everyone know the deal as soon as i get my car back.
    -Ralph
    F10 550i M-Sport
    Jul 07 2004
    socal
    Quote Originally Posted by A4ringedONE8T View Post
    Problem is that the weather has not been all that great in Sac, they cancelled the racing last weekend because it was wet and foggy. I will only go up if I know the weather will be good seeing that it is an 8hr drive each way for me.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Spoke to Mark today. He's not willing to provide his data logging software to the public.
    File switching on my ECU now works
    Made a couple tweaks to my file (nothing major). Turns out that T25 leak was there when he was tuning my car (not big though, he went back and checked things to verify all was good). I'm now running 28-29psi of boost rather than 25psi on 93oct and the car solid between 300-305awhp on that file rather than the 280ish I published a few weeks ago.
    -Doug
    Mar 19 2004
    Vegas
    Nice. Ya, i knew he didn't want to release it, but being b6 guys don't seem to have an option, and you have his software, I was curious if he would.
    Cheers! David
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Yup. I asked. Figured it couldn't hurt. We also chatted about ECuX. Know anyone using ECuX with a B6? Mark told me it won't work with the B6 ECus.
    -Doug
    Mar 19 2004
    Vegas
    To be honest, I dont. I didn't have it when I had my b6, and only chassis I know of using it are Mk4 and B5.
    Cheers! David
    Oct 29 2005
    10speed
    San Francisco, CA
    I think Greg@SSP uses ECUx on B6s but not sure
    - Clint
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Quote Originally Posted by A4 Moda View Post
    X2
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Just got a call...all of my fuel stuff is in and will be shipping to my house tomorrow...
    My only xmas gift
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by 400HPA4 View Post
    My only xmas gift
    good deal
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
