Results 1 to 16 of 16
    Veteran Member Three Rings eddiecut's Avatar
    Mar 10 2007
    99' 1.8t
    Oregon
    1.8t wont start... fuel relay? fuse?
    So my b5 1.8t sat for about 2 weeks while I have been driving my a6 trying to sell it. I started it up once and it was fine, ran it for 15 mins and shut it off... came out to start it up and take it to the tire store and it doesnt do anything.
    Makes noise like its turning over but not... so figured battery. since the safe code was on my radio and the lights were super dim. So tried jumper cables. that didnt work but gave the car a little more life while trying to turn it over, so battery might be just junk, it has been cold here at night. So went and got a new battery. NOTHING. just the same, but it tries to pop but doesnt do anything. Now what could possible happen while it sits, I drove it, parked it and it was totally fine.
    help....
    also, I put 2 gallons of gas in the tank trying with the new battery thinking the gas might be bad or something.
    Need: S4 Avant, MT, Nogaro.
    Veteran Member Three Rings B5 Quattro's Avatar
    Feb 10 2008
    2000Audi A4, '88 VW Jetta 2.0l16v, 2011 Golf....
    Hamilton.Ont, Canada
    Re: 1.8t wont start... fuel relay? fuse?
    I kinda have the same prob. Didnt start it for one day. Had trouble starting. Got it going drove it around for 30min or so. Stopped at a store and could not get it started. Locked and unlocked it and it started.
    Now every now and again it just will not start.
    No codes or anything.
    Its driving me nutz !
    So if you find out anything let me know and if I finde out anything Ill let you know.
    Mar 10 2007
    99' 1.8t
    Oregon
    I think my problem may be that its flooded...
    Feb 10 2008
    I dont think that it would be flooeded. If it was just sitting.
    Look over your stater and see if there is anything there. (problem)
    Senior Member Three Rings Black_97 A4's Avatar
    Jul 15 2007
    97 1.8tqm, Ninja500ex
    Pittsburgh, PA
    don't mean to thread jack or anything. I just had these problems today. Car would crank but not start, got battery tested still putting out 14 volts and everything was fine battery is only 2 yrs old..finally got it to start and was driving and heard thud thud thudd and everything flashed and car shut off, but started right back up....
    could it be the fuel pump or filter? where are they?
    Ethan
    1997 Audi A4 1.8T
    PICS...
    http://community.webshots.com/user/superstifler67
    ___________________________________
    Registered Member Two Rings CreamAudi's Avatar
    Jun 12 2008
    hempstead,ny
    so u can crank it over but it just wnt turn over, i dnt think its the starter cause its sill cranking it could be ur alternator not charging all the accessories.
    Cream 98 quattro
    mods
    3MM 20% tint,2 12 jlaudio subwoofers, k04-15,forge 007,Unitronic stage 2+,380cc injectors,18x8.5 asa ar2,rs4 grill,and customized floor mats(adds 25 whp), Infinity Kappa speakers and tweeters, fmic, v-maxx coilovers, custom exhaust, small lip spoiler
    Jul 15 2007
    Pittsburgh, PA
    ya my car just cranks..im thinking something fuel related
    Ethan
    1997 Audi A4 1.8T
    PICS...
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    Is the car chipped? Also check main fuel relay.
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Jul 15 2007
    Pittsburgh, PA
    ya car is chipped..has been chipped with no problems previously..for over a year..where is hte main fuel relay?
    Ethan
    1997 Audi A4 1.8T
    PICS...
    Apr 16 2007
    Queens
    Check the ecu and see if the chip came out of its socket by chance. The main fuel relay in under the steering wheel. Youll have to do a search to find the exact location. But if you remove the panel under the steering wheel it gives you access to it. looks like this;
    http://www.ecstuning.com/stage/image.../600/17489.jpg
    2003 A4 1.8TQM
    Jul 15 2007
    Pittsburgh, PA
    alright thanks i'll have to check that
    Ethan
    1997 Audi A4 1.8T
    PICS...
    Feb 10 2008
    Did you find out what the problem is or was ??
    Mar 10 2007
    99' 1.8t
    Oregon
    nope... the reason I think it might be flooded... really cold outside and I havent started it in like a week or so... my buddy who is an audi tech said this has happened to him a lot when cars sit.
    Feb 10 2008
    Oh....I didnt know that.
    Keep me posted.
    Please.
    Mar 10 2007
    99' 1.8t
    Oregon
    Yup it was flooded, took the fuel pump fuse out, cranked it over 20 times, let it sit for ten mins and then put the fuse back in and away it started. Huge black cloud came out the tail pipe. Drove it for a few hours and it was good to go.
    Feb 10 2008
    LOL.
    Really ?
    Wow. Ok I'll keep that in mind.
