Results 1 to 9 of 9
    Established Member Two Rings 2.7avant's Avatar
    Sep 08 2008
    2002 S4 Avant
    Help diagnose an engine noise
    This happens when shutting off the car
    Engine noise ~8 seconds
    Thanks
    Timing belt job has not been doen yet. I plan on doing it in the next 3 weeks
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Re: Help diagnose an engine noise
    Yes, it's called your engine is not running anymore... Mine does the same thing so I'm guessing this is normal. But my timing belt hasn't been done yet either, and it's at 95k miles >:D
    Sep 08 2008
    2002 S4 Avant
    Thank you for your contribution.... Now if anyone might be able to tell me what the NOISE at ~8 seconds is i'd appreciate it.
    I had my wife start, rev and shut down the car several times for me while i listened and the noise seems to come from the back of the engine. The sound is intermitted and is not apparent when starting running or revving the engine.
    I have had 2 suggestions: the cam chain tensioner and another that stated after changing out their clutch and adding a DTS their noise went away
    I plan on adding the snub mount when I do the timing belt and my clutch is in VERY early stages of slipping.
    Any other suggestions are welcomed.
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Does it sound like a clunking noise? I had a hard time hearing your sound clip. It most likely is your dual mass flywheel springs unloading.
    http://www.audizine.com/forum/showth...turn+car+noise
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    Quote Originally Posted by s42k5b View Post
    x2 ... i kinda heard it and my car does the same thing and i dont think theres anything we can do about it
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Sep 08 2008
    2002 S4 Avant
    OK, so you guys REALLY eased ,y mind about this. Im going to listsn a few more times to be sure but I really appreciate it
    May 31 2008
    New York
    Don't worry about it. It is normal
    Jan 12 2008
    I wasn't trying to be a jackass... It really is normal.
    May 31 2008
    New York
    Quote Originally Posted by gmann View Post
    Haha I kno it is. I was not trying to be sarcastic
