Results 1 to 24 of 24
    Established Member Two Rings lask8ter134's Avatar
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    how long do the front brakes...
    how many miles do the front brake pads typically last?? lets say with moderate daily wear and driving? and our cars are equipped with sensors in the pad correct?
    Audi A4 Non-Sline 2.0T Fwd Cvt Evo Ms Intake/Apr 91/100/Miltek 200 Cell Cat/Magnaflow Exhaust/Vogtland 35mm springs, Koni Sport Shocks/R8's Replicas w Toyo Proxy 4's/Hawk Ceramic Pads/Front Filler Plate/30% tint/Garmin 760 GPS
    Registered Member Two Rings audibehr's Avatar
    May 30 2008
    2008 a4 tit,s line
    san francisco
    Re: how long do the front brakes...
    Quote Originally Posted by lask8ter134 View Post
    Hey Man, hit me up when you get some info, my 08 has 13900.00 miles and the brakes are feeling wierd/and squeeky.. thanks. Blair
    DUH! an Audi
    los angeles, CA
    umm 15k, 20k....just depends how aggressive you get.
    my original pads lasted 18k i believe...
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    I had my original pads for +45k miles before I replaced them with Hawlk HPS pads. They still had a good amount of pad left but the brake dust was annoying the crap out of me.
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Senior Member Three Rings B7 Projectile's Avatar
    Aug 06 2007
    07 Audi A4 2.0T
    Lancaster, PA
    33K and still holding up.. They are on their way out soon, but I think that I have gotten such good results due to highway miles.. I only got the car in June of 07..Regarding squeaking, all the time @ <10 MPH..
    2007 Ibis Audi A4 2.0TFSI Ti Package
    Vorsteiner CF Hood.APR K04.APR HPFP.AWE Exhaust.AWE FMIC.034 HFC.KW-V2 CO's.Forge DV.3000k HID Fogs.Smoked Tails.Custom Intake.Heatshield.CC Mod.35%Tint.Blacked Rings.RS4 Rear Sway Bar.Podi boost gauge.
    Ah...so many pedestrians, so little time...
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    ive got around 30k on the originals and they are squeaking alot at low speeds. should i replace them soon??
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Dec 14 2006
    2007 Audi A4 S-Line
    Long Island, New York
    I'm at 25k on originals. They DO have sensors in them correct?
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    I had to replace mine at 28K along with all 4 rotors. I drive normally, but I bought my B7 with 11K so I'm not sure what happened before that. Ive been driving on slotted rotors and ceramic pads for about 6K and they havent worn at all.
    Registered Member Two Rings 08 B7's Avatar
    Oct 30 2008
    YONKERS NY
    i got 9,000 miles and their squekin?? i dont dip that much
    Nov 12 2007
    Grand Junction, CO
    I'm approaching 28k miles and just had mine checked at the dealership when I had my 25k service (which was done at like 27k) They said my pads had plenty of pad left..if that makes sense. So, I guess it depends how you drive. I'm fairly easy on my brakes.
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Ive got 102,000 miles and mine are perfectly fine and ive had the car since day one..
    P.S. No the milage is not a typo..
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Four Rings nick71692's Avatar
    Jan 16 2008
    2010 S4, 2005 A4 USP, 2008 BMW 650I Conv. Sport, 2013 Jetta GLI
    Ohio and GTA
    my 05 still has the original front rotors and pads and it has 42K. I had to replace the rear rotors and pads first, the dealership said that since the car is more rear biased than a normal car the rears go first.
    2005 Dolphin Grey USP
    USP CLUB MEMBER #210
    2008 Ibis White S-Line A4 6mt, Stasis Exhaust (Gone)
    2010: S4, Ibis White, S-Tronic (Gone)
    2011 MKVI GTI 4 Door, Carbon, DSG (Gone)
    2012 S4, Monsoon Gray, 6MT (Gone)
    2014 S4, Glacier White - fully loaded (Gone)
    2019 S4, Glacier White - Prestige
    Veteran Member Four Rings quattrosaint's Avatar
    Sep 24 2007
    Dallas
    I have 21K on my car with many track events and I have glazed the pads several times. They still work really well.
    2007 A4 Quattro 2.0T Tip
    Go Fast:Custom GIAC Tune & APR HPFP & AWE FMIC & AWE Exhaust & Labree DP & K&N Filter & Forge DV & Eurojet PCV
    Stop: ECS Stg 4 Porsche BBK
    Twisties: H&R Springs & RS4 Sway & Ti Rims
    Stunt: S4 Grill & S4 Rear & Cupra R Spoiler & TTS Wheel & 8MM Spacers & CF Trunk
    Now................Mostly parted out. Thanks everyone who participated
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    I have about 60K and mine still have about half the pad left. Most of the car's life was spent in Italy where I would drive at high rates of speed up and down the mountains, but now that I am here in NC I coast whenever I can so I don't make so much brake dust. I am replacing my pads and rotors in a couple weeks because of that reason. I could probably make it on stock for 100K+. I believe wear sensors are standard on our cars.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Veteran Member Three Rings KarimS3's Avatar
    Aug 12 2007
    2011 S4 S-tronic
    Washington DC
    My brakes squeak like crazy! i thought i was the only one but apparently i'm not which is comforting. They started squeaking ( <10mph ) at around 13k miles. when i took it in for my 15k service, they said warranty for brakes expires at 12k miles! they applied some lubricant. I pulled out of the dealership and the squeak was still there. When audi NA called for their survey, well i wasn't so nice
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    Quote Originally Posted by viziers View Post
    vizi
    On the original pads? Do you drag your feet on the ground to stop?
    Dec 14 2006
    2007 Audi A4 S-Line
    hah! flintstonin' it
    Feb 12 2004
    ‘23 RS5 Sportback '20 Q8 S-Line
    i have 34k on mine and the sensor just came on. the answer is yes, we have a sensor so change them when it comes on.
    Veteran Member Four Rings TinaTbolt's Avatar
    Sep 17 2007
    2012 C7 A7 & 2015 Q5 TDI
    San Diego
    ive got 25,000 miles on my car, and ive been the only owner - and i have a heavy foot. i still have plenty of meat left on there :)
    May 03 2008
    06' B7A4 20T Non-Sline
    Monterey, CA, 93940
    34k i think my sensors ripped off, and I replaced the pads/rotors at 36k....i barely had any pad left in the rear and esp in the front...
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    Quote Originally Posted by a4dc89 View Post
    same
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    Veteran Member Three Rings kharsnett's Avatar
    Oct 24 2006
    Indianapolis IN
    my front rotors and pads are low and i'm at 26k. the rears arent in bad condition but i want to upgrade to the ecs bigger rotors
    B7 A4 Non sline Sline Edition, High flow fog light holes, Titanium license plate screws, Cross drilled lug bolts, greasy axle, Coolant relief valve on cylinder head, Pressure relieving boost hoses, Cylinder Head Exchange program, Custom cam grind, used fuel pump follower, variable geometry front Control Arms, Automatically shifted manual transmission, 87 octane APR tune, detuned 83 Octane APR tune, Custom high flow Flex section, Custom built spark plugs, Ebay sponsored!
    Stage 3 Forum Advertiser Four Rings
    Apr 01 2004
    Orange County, CA
    I toasted front pads in 12k miles. But then again, I visited the race track 3-4 times :)
    Jan 27 2007
    NC
    Quote Originally Posted by AlexK View Post
    Naww i just do a lot of downshifting.
    vizi
