    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Headlight fault plus not dipping when turned on
    I have had this problem for a while, and it really wasn't that big of a deal to me, since I was waiting to install my ecodes and I figured that would fix it. Well, I installed those yesterday, and everything works properly, except the dip feature. The lights down dip when I turn them on or if I have them on already and I start the car. I don't have any idea what could have caused this. Any thoughts?
    -Tim
    Active Member Two Rings AudiRepair4Less's Avatar
    Apr 11 2008
    Long Beach
    Re: Headlight fault plus not dipping when turned on
    Do u have a vag com, or anything to check the fault? PLus you car is a 03 correct? does it have auto light? I dont remember if they started that year
    Mar 13 2007
    Sunny UK
    I don't have a VagCom, and it is an 03 and has auto lights.
    -Tim
    Aug 26 2005
    You must reset the "home" position, using vag-com, and aim the headlights with the controller in the basic setting mode.
    Mar 13 2007
    Sunny UK
    Thaks very much. I'll see if my buddy has received his VagCom yet.
    -Tim
