See you around!
l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
[email protected]
2005 Silver S4
RAI Supercharged
Unitronic Tuned
JHM L/W Crank Pulley
Custom 2.5" catless DPs w/Milltek Non-Res
TEAM|AXION
2005 Audi A4 1.8t Quattro 6spd
Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
Remember: Your car is unique, just like everyone elses.
Don't let your typing write checks that your body can't cash.
034Motorsport.com
01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
Aaron
