Results 1 to 16 of 16
    Veteran Member Three Rings braker15's Avatar
    Nov 15 2008
    2000 S4 Nogaro Blue
    S.Florida
    Question My audi died on me
    hey guys i need some help over here, i was driving on the highway when all of the sudden the car started to hesitate, loss of power, stalling and then it just shut off. What the hell could it be? I have apr1, and just put magnaflow exhaust and new rear brakes on the car the day before. Could it be coil packs?or fuel pump..any help appreciated!
    Jun 08 2008
    Calgary AB Canada
    Re: My audi died on me
    doesnt start again? try turning it to the ON position without starting it and see if you can hear the fuel pump start up.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    likely coil packs... did it shake?
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    you need to pull codes, this is not enough information.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    CEL (Check Engine Light)?
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Nov 15 2008
    2000 S4 Nogaro Blue
    S.Florida
    no lights came on the dash at any time, I listened to the fuel pump couldnt hear much but it smells like gas ...
    where's the fuel pump relay?
    Could it be timing belt? i have 86k miles in the car
    thanks
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Get to VAGCOM it and avoid to drive it. Actually dont drive it at all till you find out whats going on. if its timing belt related, I think you would experience much worse things than described. It sounds like fuel supply was cut or something.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    sounds like you have a massive boost leak check all vac/boostlines
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Established Member Two Rings FPBBrandon's Avatar
    Jul 17 2008
    2007 RS4, 1987 CGT, 1983 UrQ
    Arvada, CO
    Sounds like fuel pump to me. Had the exact same symptoms, Mine went out at 65k on the clock.
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by FPBBrandon View Post
    Same for me. No codes just died. Try tapping on the fuel pump. If t fires off then dies, that's likely it
    APR Stage 2/AWE Intake
    Senior Member Three Rings jokas's Avatar
    Jun 11 2004
    2003 Audi A4 1.8T Quattro
    North Jersey
    Quote Originally Posted by Papachristou View Post
    x3
    sounds exactly like what happened to me as well. was driving, car just shuts off, no warning, no nothing and couldn't get it started again.
    Nov 22 2006
    Quote Originally Posted by s42k5b View Post
    Actually, that's not a bad hypothesis. Perhaps a hose blew off or you have a big boost leak, that could definitely cause the car to die.
    2002 A4 TQMS
    Nov 15 2008
    2000 S4 Nogaro Blue
    S.Florida
    thanks for your help everyone, I was gonna go get coil packs tmrw, but seems like its a fuel pump, i shell do some testing tomorrow.
    could the fuel pump relay be the problem?
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    does ur car turn on at all? motor turns over? if not , likely fuel pump, which u replace it, go for the metal propelor one, if ur car does turn over.. and shudders like mad.. prolly coils, goodluck
    Jun 08 2008
    Calgary AB Canada
    metal impellar fuel pump? are ou sure you dont have it mixed up with the water pump?
    ive never heard anyone say that before
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    EDIT: wait...no warning or CEL lights? Probably a fuel issue then...
