and decided that pulling on the wire was a good way to do it
He reconnected the wire to the connector, but we aren't sure if the connection is good. Anyone know how to test it or got some advice? Thanks.
01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
My car is fast
00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
08 S4- Stock SOLD
