Hey guys...I'm having an issue right now with my vast mbc. My car (awe stage 3) spikes at 20psi and then holds at 17psi consistently no matter how much I turn the boost up with the mbc w/ N75. Now it will cut boost back, but can't get it to boost past 17psi. Already pressure tested and everything is good, no cel and the car is running good. Before this issue I found a small leak on the t-fittings going to the mbc and n-75, but after I fixed the leak this is whats going on? The car was running great before I fixed the leak, hitting 22psi and holding at 21psi. The mbc is maxed out right now and still no increase in psi. I'm going to reset the ecu and see if that helps. Any other suggestions?
