Results 1 to 19 of 19
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    Where to buy new DRL's?
    I just got black housing single xenon ecodes and one of the DRL's (parking lights) burnt out. Where do I buy new ones and what kind do I buy? Can I buy ones that match my xenon's? Thanks.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Re: Where to buy new DRL's?
    Quote Originally Posted by A4TUNE View Post
    i assume you're talking about your foglights....
    I have Hoen XenonMatch fogs. they match my OEM xenons almost perfectly.
    http://www.hoen-usa.com/
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Dec 06 2007
    i think he's either talking city light or amber turn signal.
    -Kirk
    BetaAlphaTau Member #58
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by AudiA4Turbo22 View Post
    ahh city lights probably. they like to burn out
    In that case, talk to Winston@Podi, i remember him having a solution for that.
    Meet Shanice...
    For Sale:
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Winston's got the regulators, but no bulbs. At least not LED :(
    Sep 14 2006
    Mass
    guys i'm talking about the little LED's the go right below the high beam projector. you won't have these unless you have ecodes.
    i need to replace one of the leds it burnt out. anywhere to get them?
    -Max
    Sep 14 2006
    Mass
    I think it's called a "wedge bulb"
    -Max
    Dec 06 2007
    that's a citylight u nooob!!!! wow i thought u schooled me in this stuff haha.
    -Kirk
    Oct 23 2007
    Ontario, Canada
    hoen also sells city lights.
    Meet Shanice...
    For Sale:
    Sep 14 2006
    Mass
    ha yeah if you're a canuck its a city light. if you aren't then it is a parking light or a DRL (daytime running light). btw it says parking light out on my dash so that's what i'm going to refer to it as.
    so I can get these at Hoen? might have to do a little xmas shopping for myself and get xenon colored matching fogs and replace the city light bulbs. Thanks!
    -Max
    Sep 14 2006
    Mass
    Can someone confirm if these are the correct bulbs I should be buying?
    Xenon match foglight - H11 Hoen 55W xenonmatch bulb
    Xenon match citylight - Hoen W5W city light high output
    -Max
    Sep 14 2006
    Mass
    bump is this correct ^^.
    -Max
    Oct 23 2007
    Ontario, Canada
    the foglight is correct..dunno bout the rest :-P
    Meet Shanice...
    For Sale:
    Dec 06 2007
    correct SEE called a city light
    -Kirk
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Citylight = W5W or Sylvania 168
    Advance, Pep Boys, etc. carries the 168 bulb. It's a 5 watt Wedge bulb.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Oct 23 2007
    Ontario, Canada
    don't try to call me a canadian
    Meet Shanice...
    For Sale:
    Sep 14 2006
    Mass
    ha thanks guys .
    -Max
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    I think that one you can pickup very cheap at Mercedes Dealership,
    that's where I got mine, couldn't wait for Xenon matching ones and got these instead. They're dirt cheap comparing to other sources.
    Audi = VWNN10445502
    Benz = 000000-000172
    EDIT: The above were for H6W, my housing used different city light bulb
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    def called LED daytime running lights with audi.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
