Porting- In the porting process the intake and exhaust ports are carefully reshaped (or should be if the porter really know what he/she is doing) by hand. This reshaping consists of enlarging, straightening, and streamlining to get rid of as much pumping-loss inducing restriction, turbulence to increase the flow velocity of the cylinder head as much as possible while make as much HP as possible. Most of the time ports are straightened by a die grinder and a carbide bit to a line of straight configuration. This straightening process gets rid of any bends that may cause turbulence in the head. This doe grinder that they use also is used to get rid of too cutting marks, sand casting pits, and usual bumps and lumps that are made by the mass production of our cylinder heads. Another process to gain more volumetric efficiency out of the head is called, extrude honing. This is where thick putty like goo full of abrasive is pushed through the cylinder head, enlarging the ports, just like the natural flow of your motor would like them to be. There are limits to porting though. You can make ports to big. Symptoms of a head that has been ported to much are a soggy bottom end, not making power. The other is a lumpy idle. The type of porting for your car will depend on the type of set up you want to run. Turbo cars like smaller port, high velocity ports without a lot of overall port volume. Nitrous and supercharged cars like the bigger ports with more overall port volume. The N/A street motors like the smaller, high velocity ports, like the turbo cars. Drag N/A motors will tend to like the bigger ports, this gets rid of the bottom end, but they want top end so it really does not matter.
- Valve jobs- this is another major factor in getting the most out of your head. Truly, a 50% of head flow gains can be found in the valve job.
1st- there is a throat cut typically around 60-70 degrees. This will help the ease of the air’s transition to the 45-degree valve seat cut.
2nd- there is a 45-degree valve seat cut, which is literally where the valve actually seats.
3rd- this is called the top cut. This cut is immediately after the seat cut and is typically 30-20 degrees. This cut also helps to reduce valve shrouding of the airflow past the valve (or before if we are talking about the exhaust valve) as the valve starts to lift of the seat. There are five-angled valve jobs, but I think for the most part they are not needed, that is why I am not going to get into the five-angle valve job process..
Read this link you will find good info about large port having less velocity verse small port having much more. http://www.patentstorm.us/patents/64...scription.html
