Results 1 to 10 of 10
    Account Terminated Two Rings
    Feb 23 2004
    A4 1.8t 2001
    Occassional start issues, need to stomp stomp stomp to start the car...
    Every once in a rare occasion my car will not crank at all. Usually this will happen when I have someone in my car, such as a date.
    I will have to stomp the clutch and try to start a few times. Sometimes it starts after 4-5 attempts, sometimes longer.
    It doesn't crank though, and then one magical time it will crank and start perfectly fine. I dont know if this is an issue related to the switch the clutch presses to allow you to start the car, or if its another issue.
    Ive just solved it so far by stomping the hell out of the clutch and multiple attempts to start the car. Any ideas?
    Mar 23 2008
    Queens Ny
    Re: Occassional start issues, need to stomp stomp stomp to start the car...
    had this happen to me a month ago then after a few days it started up fine everytime before i would of had to slam my clutch pedal and that one magic slam would start up car.. it went away and then my alternator went.. hope that helps maybe
    Feb 23 2004
    A4 1.8t 2001
    Quote Originally Posted by mkturbo3 View Post
    i actually just changed the alternator a couple months ago as well. Still with the same issue. Did it go away once you changed your alternator?
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Maybe your clutch pedal switch/sensor is going bad or sticking. It's a switch that senses when the clutch pedal is pressed.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 23 2004
    A4 1.8t 2001
    do you happen to know that part number for the switch?
    Nov 16 2008
    Pacifica, CA
    maybe it doesn't have anything to do with the clutch? sounds like it could be a faulty starter.
    Deactivated Two Rings
    Jul 19 2007
    Riverside, CA
    3B1 911 807 A
    Start Inhibitor Switch.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    sounds like a clutch switch to me.
    i replaced it in my car, but ive heard you can just connect the wires to close the circuit with no issues
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Mar 23 2008
    Queens Ny
    just had my alternator rebuilt today gonna be putting it back later tonight.
    Feb 23 2004
    A4 1.8t 2001
    Quote Originally Posted by maxspeed View Post
    any idea how i would do that? cant find any info on it....although I'm not sure if i need to go all the way there since this problem is so random and not so often..
