Results 1 to 36 of 36
    Senior Member Three Rings 03CrysBlueB6's Avatar
    May 12 2008
    washington
    snow driving?? few questions
    in the northwest it is supposed to start snowing within the next few days so i thought this might be a good question to ask.. what is the best/safest way to drive in the snow.. i mean as far as settings... like ESP on.. tip tronic?? or no??
    any help is appreciated
    B5 A4 - silver [gone]
    B6 a4 - Crystal Blue [current]
    FS: B6 A4 sport struts with about 30k on them
    WTB: S4 or USP front
    Door Blades
    Rear Lip Spoiler
    USP or other Rear
    Veteran Member Three Rings SKIDMRK's Avatar
    Sep 14 2006
    Monroe, WA
    Re: snow driving?? few questions
    esp on, watch your speed, give yourself plenty of room to brake.
    and stay off of 405 near woodinville for the next few days.
    epitome - Like McCormicks, we're seasoned
    achtuning - podi
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    ESP on keep it shifting automatic. Give yourself like 3 times the distance you think is safe.
    High speed Ferrari movement...
    Senior Member Three Rings notob6's Avatar
    Nov 23 2006
    B6 a4 1.8t
    Chicago
    when i first started driving in the a4. if i started to slide i would just jam on the brake and hope nothing bad happens. but after messing around for a little i realized its better to just stay on the gas and let quattro do its thing.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by notob6 View Post
    ....i realized its better to just stay on the gas and let quattro do its thing.
    Not the best advice to give to a newb.
    If you're Tiptronic, leave it in "auto" and as mentioned above, gibe yourself 2-3x the normal dry stopping distance if there's snow.
    Ice, be even more careful.
    Traction can me modified by throttle control, learn to take it easy, and you should be fine.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by djwimbo View Post
    I disagree... In heavy snow, don't use the brake. Keep the gearing between 1 2 and 3... I never go above 3 in heavy snow. 1 and 2 will be for steep hills and things. Also, think about physics. In a straight line, your not going to go flying off the road, you could do 100mph if you wanted to (just an example, in snow I wouldnt do more than 40). It is the turns that mess people up. Any slight turn could make the car want to slip. use the shifter to make sure that you never touch the brake. If you use your brakes in a turn, it may cause the wheels to lock up even for a split second, which could be just enough to send your car sliding
    - Clint
    Senior Member Two Rings kbasham03's Avatar
    Sep 07 2008
    02 a4 1.8tqm, 91 Talon Tsi AWD
    Streamwood, Il
    Put it in 2nd, 20 or so mph turn off esp, cut the wheel, floor it, and enjoy some nice awd donuts. Oh, you wanted safety? Well make sure you do it in an empty parking lot.
    Dec 19 2007
    York, PA
    X2...use your transmission to slow you, not the brake
    Registered Member Two Rings monkey323i's Avatar
    Apr 15 2008
    cke
    updated news for upper washington state & west coast canada:
    heavy snowfall storm arrive on friday evening and contiunes til sunday.
    Last yr had so MUCH fun playing drifting with Quattro, even the parking lot security was enjoying watching us playing drift.
    That was the time I realized how important Quattro is in snow even though my All-season tires are worn out already. (ESP barely lights up!!)
    Before I had RWD and FWD, and driving in snow is nightmare, especially for RWD.
    anwayz, if yours is Quattro, I think you'll be fine if you drive and turn in gentley.
    But, while yours is Quattro, doesn't mean others are Quattro-gripped. Always watch out for nearby drivers as they may lose traction and hit your back or side.
    if yours IS FWD, then u'll need to drive and turn in very gentlely.
    Senior Member Three Rings Johnnada's Avatar
    Aug 02 2008
    04 Audi A4 3.0, 09 BMW 328 X-Drive
    MA
    Quote Originally Posted by kbasham03 View Post
    haha
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Hmmm. And not a single person suggested winter tires.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    who needs winter tires.. im rockin staggered 19"s with summer performance BF rubber and i live in snowy michigan... Пивка для рывка, and handbrake through the turns buddy
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Quote Originally Posted by Tgr_Clw View Post
    +239847239847
    To say the least, I found this out the hard way last year. Quattro well help you from sliding sideways and getting out of somewhere you are stuck. It does not do much while braking, thats what ABS is for. Neither Quattro nor ABS will be as useful if you have nothing to plant yourself to the ground with.
    DG '02 A4 1.8TQM
    My Build Thread
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by EUROaleksey View Post
    Lol. Экстремал бля.
    Appearance: OEM+
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Good tires are key and driving cautiously will keep you on the right track since it the other cars I worry about when driving in the snow. Not using the brake in snow and ice is key no matter what you are driving... I met a lady in Vermont last year that traded in her A4 for a Suburu Forester and said she so regreted it, since she truely felt the quattro was superior in snowy and icy conditions.
    Veteran Member Four Rings BEESIX's Avatar
    Nov 06 2007
    B6 A4
    The Windy City
    lol im with u on ebrakeing it thru the turns broski, us fronttrsh owners need 2 stick together
    2002 White A4 1.8T 5MT Fronttrash with a few goodies
    Premier MotorWerks,
    2494 Oakton St, Evanston, IL
    http://www.facebook.com/profile.php?id=100001076103808
    ^ This is what i do^
    Adil
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    scared of not stopping fast enough in the snow?
    SLAM IT!!
    my car is a god damn snow plow in like 2 inches!
    just don't get high centered
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Buncha motorcycles
    Memphis, TN
    good advice
    APR Stage 2/AWE Intake
    Veteran Member Three Rings dewey527's Avatar
    Mar 10 2008
    '02 a4 1.8tq, '05 tahoe
    Puyallup
    stay off the road 405 and I5 will be parking lots. just because you have esp and abs doesn't you can stop on icey roads with summer tires on. i concur with the others, give plenty of room. i have blizzaks on 16 wheels and i can pretty much go any where but i don't have them on yet...
    mods - not enough for me and way too many in my wife's opinion
    K04, Revo "Stg2", PODI Boost Gauge, TT225, fmic, Forge DV, Tantrumwerks 300cell HFC, Neuspeed Exhaust, Stasis Touring Suspension, Spec Stg2 & LWFW, 034 RSB, Neuspeed SS, Neuspeed Snub, Neuspeed TIP, B6S4 front brakes, Tyrolsport Kit, 6K HID, Yellow Fogs, 20%, CC
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Quote Originally Posted by BEESIX View Post
    he is gonna be in Chicago this weekend lol
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I also try to slow down thru downshifting and keep going on low rpms
    Veteran Member Three Rings Hamotee's Avatar
    Oct 30 2005
    Other German Stuff
    Athens,Ga. Clemson,Sc
    Just don't trash the PS pump and rack doing too many donuts.
    How to account for this massive success? Pure luck? Transcendental meditation? Machiavellian manipulation? Aerodynamics? High colonics? We haven't the slightest idea. -P.L. Newman
    Mar 27 2005
    The Cold North
    The best advise i have for you is: Bridgestone Winter Driving School. It is a blast and you will learn a ton.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Jun 08 2008
    Baltimore, MD
    Another thing I would do if you're relatively new to snow driving... after some nice powder falls go to a parking lot that you know will be abandoned and doesn't have potholes. Drive around the lot and practice emergency stops, hard turns and evasive moves. Even once you get good a driving in snow, when you first get on the road and there's no one around, give it a good hard test stop. I say this not because it's fun but because it gives you an idea of how much distance you need to stop the car in THAT particular type of snow. Each type of snow is a little different.
    Nov 23 2006
    B6 a4 1.8t
    Chicago
    Quote Originally Posted by Rockclimbersh View Post
    thats definitely some good advice. first time i drove in snow i almost crapped my pants while learning how long it takes to stop.
    Veteran Member Four Rings GQ//S4's Avatar
    Jul 25 2007
    Today?
    North of Seattle in trees, WA
    Do everything slower than if it were dry... Brake earlier, don't slam on the gas or the brakes or you'll break traction and/or lock it up, making you into an ice skate, plan for turns before you get there.
    - Michael
    Fact: I'm Awesome
    Former: '92 911 C2, 01.5 S4 Stg 3, 00 S4
    I always dreamed of walking on clouds, so I drive on air
    My logic is infallible. Always.
    Grammar Nazi #1
    "I'm too close for missiles, I'm switching to guns!!!"
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    dont drive like an ass. be sensible. in other words, dont be a BMW driver in winter
    i had to drive my first witner in a nissan maxima with summer tires. no traction control and shitty tires and bad abs makes for a hell of a time.
    engine brake to disappate speed, using your brakes too much will make you lock up and not stop very quickly
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Active Member Two Rings uber_boost's Avatar
    Jul 12 2007
    03 Audi A4 1.8t
    Toronto, Ontario, Canada
    Get yourself a set of blizzaks WS60 ... quattro will get you out of the snow but will not help in coming to a stop...and it works better with winter tires....
    My other top picks for winter tires are the Michelin X-ice Xi2 and Hakkapelliitta RSi
    P.S I love it when you can act a fool in the snow and you have RWD's Hating on you :P
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    I love effin around in the snow with my A4. No matter what I do, I can always recover with Quattro. :)
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Jul 25 2007
    Today?
    Quote Originally Posted by tamaneri View Post
    Yeah, I felt that way last winter, until my Bridgestone Potenza SO-3's froze and stopped gripping ANYTHING. New all-seasons this year are proving more than worth the money already.
    - Michael
    Fact: I'm Awesome
    Grammar Nazi #1
    Jul 12 2007
    03 Audi A4 1.8t
    my pirelli all season had no grip what so ever in anything more than 5cms of snow... all seasons are no season tires... makes a huge difference if you put proper tires on
    Sep 20 2008
    Honolulu, HI
    ESP = Engage Snow Play
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    Man, reading all this is so weird. I'm from California. Winters here get down to about 60F. Are there any special driving techniques I should learn?
    :D
    Jul 12 2007
    03 Audi A4 1.8t
    yes...dont drive up north
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    ahahahahahahah
    Feb 12 2005
    Denver
    All-seasons are essentially a joke compared to a high end snow tire with Quattro. Been there, done that. It's the difference of getting around "ok" vs snowmobile. Perhaps some of you guys don't need to drive much in tough conditions, but here in Rockies they are a must for frequent mt/pass travel IMHO. Run my Quattro with Blizzak LM25 (performance snow) on the 17" sport rim (winter rims). No problems with snowpack, ice and up to 10" snow. Car begins to float in anything deeper due to clearance. Frontrak with high end snow > Quattro w/all-season. Drove both drivetrains for 2+yrs each, with Quattro as current.
    FYI, use caution when running high performance summers consistently in dry conditions below 35-40F. That can be scary when having to hit the brakes hard. Tread turns into a brick. Opt for all-seasons in this scenario.
