hmm I see!
What if I start the car from dead cold,
and the initial idle rev is around 1.2-1.1krpm,
then i let it idle without moving the car around...
after 1-2 minutes...the rev comes down below 1000rpm,
around 900-800rpm~
is that a bad thing to do?
Another way I've tried is start the car, step on the gas pedal(only for few secs) lightly while idling, and the rev will come down much faster...
if these aren't too clear... let me know! i just wanna see how you guys respond to my warmup habit so that I can change!
Originally Posted by
AlexK
Cylinder walls are lubricated by oil being flung up onto them by the crank. When your engine is idling and cold, your crank isn't spinning fast enough to adequately lubricate the cylinder walls.
Letting your engine idle isn't bad. But letting it idle to warm it up is.
The right thing to do turn your car on, give it a few seconds to build oil pressure and start driving keeping the revs below 3k and out of boost.
