Results 1 to 8 of 8
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    So i just cleaned my maf... (pics)
    A couple days ago i installed a cone filter & heatshield that i got in the classifieds. The previous owner of my car put an oily-ass K&N filter in there and i figured it would probably be a good idea to get rid of it. So today i decided to clean my maf for probably the first time ever. I took the sensor out of the housing and sprayed the shit out of it with the CRC maf cleaner. I let it dry, and put it back in. It didn't make a difference at all, but i guess it's good that i did it.
    But when i was cleaning it i noticed something, there were lots of specks of dirt that wouldn't come off no matter how much cleaner i sprayed on it, and the gel-like surface had a huge crater in it. Does it look like it needs to be replaced? I've been trying to figure out why i've only been hitting 15 psi on GIAC software, i have no boost leaks and a brand new n75h so after ruling those out i wanted to check the maf. Would you get a new one if you were me?
    {99.5 Avant}
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    Re: So i just cleaned my maf... (pics)
    if you or anyone has a vag u can do some maf readings
    2018 Mercedes GLC 300
    May 22 2008
    az
    i was considering that, since i also wanted to log my throttle angle at wot, whatever block that is.
    i don't have any vag com experience though, could i just use one of the handheld readers for this, or do i need the version that uses a usb cable + the $300 software?
    {99.5 Avant}
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    how many miles are on the car. they need to be replaced eventually anyway so.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    May 22 2008
    az
    almost 127k.... they definitely aren't cheap and i really hope there will be a tangible improvement if i spend the 200+ bucks for a new one. it's old and it looks pretty fucked up, but my idle is still really smooth so i am hoping i can get a few more miles out of the current one.
    {99.5 Avant}
    Sep 20 2004
    2001 a4 quattro
    Sactown
    you have a 99.5, and your giac chip is 1 bar 14.7 psi, whats the problem with 15psi?
    May 22 2008
    az
    i was under the impression that the giac file was 1.3 bar. it seems like a lot of guys around here are hitting 18-20psi on a chipped K03, or else i'm trippin
    but i took the car out for a 2 hour highway run today, and i was spiking to 17ish instead of 15 so i guess cleaning the maf helped a little. i definitely felt a small difference at wot.
    {99.5 Avant}
    Sep 23 2007
    you can get a brand new maf for $140 shipped here www.mjmautohaus.com
