    Registered Member Two Rings RSMESS's Avatar
    Nov 12 2008
    01 TT Quattro (180)
    bel air, maryland
    Question rear speaker removal?
    i have a horrible rattle in my back speaker. i think its blown but i cant figure out how the FUCK its supposed to come out i dont see any bolts or screws on the damn thing and ive cracked the speaker grille twice trying to get that off.. anyone have any suggestions?
    Oct 13 2008
    Rochester, MN
    Re: rear speaker removal?
    Well from doing this myself recently heres how it goes. There is a write up of this on audiworld as well- credits goes to them. I also wouldnt have figured it out.
    1. Disconnect the rear brake light in the trunk
    2. Remove the bottom cushion of the rear seat- it can be pulled up and removed.
    3. Put the rear seatback down
    4. Unclip the side bolsters on both sides of the car (the only part(s) of the seat that dont fold down next to the doors). These are a struggle, you can visually see the bottom clip however the top one you cannot. Push up and pull out or however which way it'll release for you. It may take a few tries. The bottom clip is somewhat pliable.
    5. Unclip the seatbelt mount covers.
    6. Simply lift up the rear deck to unclip it. Be careful not to damage the speakers while removing or re-installing as this process can rip the speaker cones.
    As a side note if you're going to install new speakers, you'll have to re-wire the pre-amp thats bolted to the driver side speaker. Green is positive, black is negative.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    3 bolts under the baby seat clips, pry the clips off and you'll see the bolts. then unclip the 3rd brake light and the rear shelf comes off. then its screws for the speakers
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    ^^ what he said! thats the easiest way!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    May 09 2007
    jersey
    does anyone have pics of this
