Originally Posted by
3 bar
It shakes in neutral
So it's probably not the motor mounts or anything in the trans or diff. You can check the mounts by:
opening the hood and have somebody stand off to the side.
With the car started, put it in gear, apply the brake, and step on the gas while the brake is being applied.
If you see the motor shift positions, then you probably have a bad mount or several.
As I mentioned, I don't think that your mounts are bad but it's worth doing to eliminate this possible cause.
Does the car have full power or does it feel like it's running on 7?
