Originally Posted by
maxspeed
whats you timing looking like? exhaust size? got a cat? octane?
sorry for the 21 questions, but i thought a full gt28rs would be a tad faster
I still have to take some logs of the timing per cylinder. I did a run in second gear but it was too quick so I didn't get any useful data.
Exhaust size is 3" at the downpipe (catless ATP) rolling into a 2.5 to 2.75" Neuspeed catback setup (no resonator/one muffler).
And the fuel octane is 93.
biketsai
Nice Chris! Unfortunately I am still running into problems, soon to be solved. Id like to hear more about that tune etc.
The tune I have now seems to be a little bit slower than the old tune but I don't get the check engine light for having the MAF disconnected and I can also remove my SAI system as well as a few other things. I was in a 4.8 ~ 4.9 CAPs time range before but that was also under 22 psi of boost so that had an effect on the results also.
What else do you want to want to know about the tune? I'll have some more logs soon.
Poopie
run 23 psi and it should be in the 4's which is pretty solid.
Yeah, once I get the throttle plate for the meth injection put on I am going to take some logs and bump the boost a little bit.
Don Supreme
If put the maf back on the evap will pass.
Really? This is a MAFless tune though. I was hoping I wouldn't have to use the MAF unless the mood strikes me.
I'll give it a shot tonight to see what happens with it.
