Results 1 to 8 of 8
    Senior Member Three Rings lifwanian's Avatar
    Oct 17 2008
    Dirty whores.
    NV
    Whaaa??? A little loss of power?
    So my car was pretty much stock. Its a 99.5 1.8tqm.
    Its got the cone intake (was there when I got it) and a super shitty heatshield. I'll be gettin the good one soon.
    It was running good. Then about a week ago I got the MTM stage 1 chip. It drove amazing! It was super fast. The throttle response was great too!
    Then recently, I noticed a little drop in power. It still drives fast, it just seems like it takes more to get it going, and its just not as fast of a response. For example, I drive exactly the same, and I killed it twice now because it takes more gas to get goin... Could it be because of my stock diverter couldnt handle it? Or because my intake? Too much hot air in it?
    Once I get above 3k, the turbo does still kick in hard, just not the same as a few days ago... :(
    I mean it could be just that I got used to the car, and just want more power, but I just want to see if anyone has run into this?
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Re: Whaaa??? A little loss of power?
    I think I ran into the same thing on my A6. When I first got it I was like woooaah this is sick but now I'm pretty used to it. I'm going to set it back to stock for a week when it gets super cold in PA and then when its a little warmer set it back and see if it feels the same again.
    Senior Member Two Rings Stumanbmx's Avatar
    Nov 04 2007
    '00 A4 1.8TQM
    Minnesota
    Same thing happened to me with my GIAC. Except it happened in only a day.
    Registered Member Two Rings RSMESS's Avatar
    Nov 12 2008
    01 TT Quattro (180)
    bel air, maryland
    the same thing happended to me with APR. after that i changed the oil and it actually helped out a little. it could also be the gas that you put in.
    Oct 17 2008
    Dirty whores.
    NV
    Haha wow looks like were all getting into this...
    I just recently got the Full synthetic oil change. I also put premium at the good gas stations too! I make sure to stay away from shitty small ones...
    Those of you that have had this, do you guys have an upgraded diverter valve?
    Oct 17 2008
    Dirty whores.
    NV
    Anyone have an idea?
    Dec 05 2007
    Keep your car happy. You should have upgraded the dv before you even got chipped. I did that along with plugs (the ones I chose do not need gapping, so it was ok) and did the dv maybe a week before getting my ECU flashed. But yeah, def get a new dv. That could be your issue as you might be loosing pressure there if it is defective. I also only run the good stuff in my car. Amsoil 0w30 currently and will switch to 5w40 european formula when the summer is back. Ran the Lucus injector cleaner, changed my filters, have fresh plugs in, etc.
    My advice is to get an upgraded dv (I run with the Forge 007 w/yellow spring). I would not be suprised if you ripped your stock one already. Do you have a boost gauge? And if so, how much psi you spike at? And if you don't have a boost gauge, you should def invest in one very soon.
    Oct 17 2008
    Dirty whores.
    NV
    Ok thanks!
    Yeah I am about to order a diverter valve, and I have a boost gauge on the way. Should be here mid next week...!
    Hopefully that will help!
