Results 1 to 6 of 6
Thread: HID question...
    May 21 2007
    Florida
    HID question...
    ok this is probably a dumb question, but i cant find the answer so im going to ask it.
    i have stock xenon lighting. i like the look of my friends 6000k HID setup in his jetta. can i just get 6000k bulbs and run them off the stock ballasts? or would i have to get a whole new kit?
    2018 Navarro Blue Q5
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    Re: HID question...
    im pretty sure you'll be able to run a different bulb off the same ballast.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: HID question...
    Sure. Find some 6000K D1S bulbs.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Oct 16 2006
    Naperville
    Re: HID question...
    Yes you can... D1S or D2S bulbs??? i was thinking of going 6000K with my D1S setup, but bulbs are too pricy.... i've only found the philips one.
    May 21 2007
    Florida
    Re: HID question...
    im d1s currently, but kind off confusing and semi-hard to explain what im doing...
    i PMed with HIDCONCEPTS a while back because i was looking into the ebay ecodes, which just baught off a member on here. HIDCONCEPTS told me i could run my stock xenon setup in these housings with d2s bulbs, adapters, and ignitors. this would all run me about the cost of a HID kit. so i will be looking for 6000k d2s bulbs. reason im doing this over just getting a HID kit is simply because it seems that there is a slot already in the bottem of the ebay ecode housings that will fit the stock ballast rather nicely, instead of a bulkier aftermarket one.
    edit: found the phillips too, $110 per bulb. yikes!
    anyone know what 6500k looks like? in terms of color....found some for $65 each, not bad.
    Oct 16 2006
    Naperville
    Re: HID question...
    yeah thats why i stock with 4300K haha
