Results 1 to 13 of 13
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Any 12VDC Electronic Gurus in 'da hizouse?
    I want to somehow have LED dim when headlights are turned on. Is there any type of relay or anything that would trip when the 12V hits the low beams and then dims the LED (not off, but dim). And when the lows are switched off, the LED go back to bright running lights?
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Three Rings orangelmo's Avatar
    Jul 05 2007
    Stouffville
    Re: Any 12VDC Electronic Gurus in 'da hizouse?
    Maybe you'd have to have it go through a voltage regulator or something after the relay. Less voltage = dim LEDs. Just a thought not even sure it would work
    Feb 28 2006
    Pittsburgh-Philly
    That's kind of what I'm thinking, but I wouldn't know where to source parts like that, or exactly what I'd need.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Instead of a relay, it would probably be easier to run two separate power sources to the headlight and switch between the two. You may want to look more into LED dimming as well. It is not as straightforward as other lights.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Feb 28 2006
    Pittsburgh-Philly
    Yeah, was hoping it'd be something simple. Thanks, Greg.
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Pulse Width Modulation
    A far superior method of dimming LEDs is to use Pulse Width Modulation (PWM). With PWM strings of LED bulbs can all be driven with the recommended forward current, with the dimming achieved by turning the LEDs on and off at high frequency - so fast the human eye cannot see the strobing effect. The longer the on periods are relative to the off periods, the brighter the LEDs will appear to the observer.
    Simple google search.
    http://www.reuk.co.uk/LED-Dimmer-Circuit.htm
    I'm sure there is more to it than this, like building a circuit and controlling it manually. Might be more of a pain than anything else. Maybe get two different sets of LEDS, ones with a high Lumen output and the others with a low and something that will just switch the two.
    Dec 06 2007
    make it like the LED tails when u push the brake they go bright u know same idea.
    -Kirk
    BetaAlphaTau Member #58
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by AudiA4Turbo22 View Post
    Yup, except, how is it done?
    Dec 06 2007
    try this website scroll down
    http://www.mikesflightdeck.com/led_dimmer.htm
    -Kirk
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    I can help you with this, but I first want to know how much current your LEDs (the whole string) takes. You can get it from the manufacturer's docs, or if you have a multimeter, disconnect one side of the LED string and connect the meter (in current mode) between the two open ends. Tell me what you get.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Dec 06 2007
    exactly multimeter is what i was trying to remember
    -Kirk
    Dec 06 2007
    thanx for the +rep Condo!
    u can also try matching the number of LED's in the A5 headlights and spacing them out similarily.
    seems to be 8 so ur right on par.
    -Kirk
    Dec 06 2007
    -Kirk
