Results 1 to 16 of 16
    Veteran Member Three Rings Sigma 3's Avatar
    May 23 2005
    Tricities Wa
    GT 3071 + stock mounts
    Have any of you had issues with mounts breaking or getting exessive drive train lash under hard boost?
    TIA
    Originally Posted by FNK re getting more power from a 2.8 a4
    "Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
    Dec 05 2007
    Re: GT 3071 + stock mounts
    It is def a recommendation to replace the motor mounts when upgrading the turbo. My mounts are even starting to go with my stock turbo (yeah, at times I like to ). FWIW, I seen a set of RS4 motor mounts being sold in the classifieds for $100 used (don't know how many miles). But even then, many would still recommend the 034 steet/track density mounts. I was contemplating on purchasing them, but was reluctant. I might still.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I don't have a BT/BAT, but I'm rocking the Street Density mounts, and I love 'em.
    I still need a DTS, but I'm not paying >$150 for one. I will be making my own, sometime in the next year or so.
    Feb 27 2005
    North Wales, PA
    make mounts out of hocky pucks....like i will. hahaha
    97 A4 2.0TQM
    Rochester, NY
    034 snub mount bracket + snub mount
    DTS (ASP is cheaper than AWE)
    Apikol rear diff mount & bushings
    with those 3 things you dont need to touch the motor or trans mounts. I have stock 1.8t mounts for motor/trans, and the engine doesn't move at all even under hard launches.
    Sure, they will help, but you'll notice much more by buying the things I mentioned above first.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I"m running S4 motor mounts in mine....had em for about 2 years. They were fine with a chip, but I definitely do get a lil more drivetrain movement since going BT....I'll be getting Street Density mounts soon tho
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by djwimbo View Post
    Just get the rear diff mount bushing and power ring, for less than $125 . No need for a DTS, you need to upgrade the bushings on it anyways, and it becomes the lowest point of the car too
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    power ring?
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by t1demont1 View Post
    power ring?
    http://shop.dthaus.com/product.sc?ca...1&productId=11
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by 317ssayzarc View Post
    Bushing? What bushing, that shit's going to be solid. I don't have a glass ass.
    Ok, maybe I'll put something in between the trans and the mount.
    Lowest point of the car ... right now my exhaust is, BUT I have a few things in mind. More info hit AIM or PM me.
    Senior Member Three Rings Avant1.8BT's Avatar
    Nov 05 2006
    mycar
    Quote Originally Posted by Poopie View Post
    i saw you posting that in another thread...
    we need pics for proof when this happenes.
    May 23 2005
    Tricities Wa
    Thanks fellas.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    DTS isn't really needed if you run aftermarket engine and tranny mounts.
    He is talking about the bushings in the rear mounting plate.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    As much as that's true, for me apparently it's not. I still get some movement when transitioning from a WOT to decel.
    And I wasn't talking about the rear diff mounts when I said they were going to be solid. I meant the DTS, I will be making one for my car. It's part of another project, a project that won't be explained in public forums until it's done.
    The rear diff mounts though, well... they'll eventually be solid. I already broke 'em once, so as soon as I learn to TIG I'll make my own.
    front mount
    Rear carrier
    It hasn't happened since, and I've driven it harder, but I don't want that to ever happen again. That's why I was scared to launch it for a <2.0 60'. I kept remembering that event, and the cost.
    Jul 07 2004
    socal
    front mount
    Rear carrier
    Odd that it broke on you. I wonder if it has to do with the cold conditions where you live.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    the rear carrier had a chip out of it from some external damage. It looked like something was backed over and it took a bite out of the rear carrier. When it broke it started there and went upward.
    After looking at the break though, there wasn't a previous crack that was extended, it just plain broke. Meaning there wasn't any of the nice "polished" looking spots in the break, it was all fresh stress issues. Nothing fatigue related.
    I don't have any pics of the damage before it broke, but the piece that chipped/broke off was no bigger than the file from a nail clipper.
