Results 1 to 40 of 70
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Pulled the GT35r out.
    Removed the compressor housing, looks good.
    Pulled the turbo out of the exhaust housing and WOW.
    There is no shaft play. I am really suprised I was able to run 10.5, traps up to 136 mph and make the power it made on the dyno on saturday. Oh well, now have to talk to FP to see if they can replace the exhaust wheel at the same time they do the HTA upgrade or if I will have to just buy a whole new turbo.
    Dec 05 2007
    Re: Pulled the GT35r out.
    Do you know how your turbine fins turned out like such? Any thought what got into the exhaust housing? Also, about how many miles on that turbo? Thanks!
    Oct 29 2005
    10speed
    San Francisco, CA
    interesting
    - Clint
    Oct 30 2006
    B8 A4 Avant 6spd
    Wow how the hell did that happen? Mileage?
    -18 718 GTS
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    ouch..
    Jul 07 2004
    socal
    Hard to say how many miles are on the turbo, but it went into my car before the 1.8t Challenge back in 2004.
    Not sure what went thru the turbo but my plugs dont stay in my car very long and I have never pulled out a damaged plug.
    Sep 17 2006
    07 cbr600
    damn
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    should we reiterate the high EGT discussion from the B6 A4 thread?
    So you're going with an HTA, or is that a cover story to something F-in amazing?
    Jul 07 2004
    socal
    Quote Originally Posted by djwimbo View Post
    Damage doesn't look like it is from high EGT's since it is jagged not melted. Something could have gone thru the whole engine and then thru the turbo. I mean this could have happened long time ago without me even knowing it since the car has always made good power.
    The plan up to just now was to ship it out to FP to have it upgraded to the HTA86, but now I am waiting to hear back from them about this damage before I make up my mind what I do. I already have someone that wants to buy my whole setup if it includes a HTA3586r.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    to say you put down 550whp on a broken turbo is pretty damn cool.
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by maxspeed View Post
    What he said.
    as far as the damage, I don't know. I've never really had the opportunity to have an issue like that and be able to fully diagnose it.
    That's not something you normally see in a dealership setting. And I definitely have limited experience with B5's and 35R's (or BAT's) anyways.
    I just thought I'd ask.
    Aug 05 2008
    Highland
    pics look bad. quote above is true. i hope you get an HTA wheel and then bring the car over here for next years WF.
    97 A4 2.0TQM
    Rochester, NY
    Wow, weird...it looks like it melted to me. I'm surprised there's no shaft play, since that thing is probably way out of balance.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    I guess its safe to say the hta will put you in some low 10s
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    It's ok, non HTA turbos are gay anyways!
    Oct 29 2005
    10speed
    San Francisco, CA
    Mike do the HTA son, it would cost maybe a little shy of $1k to have the exhaust wheel and HTA done but with that you would have to buy a plain GT35 anyway
    - Clint
    Jul 03 2008
    A4
    friend just sent his gt35 off to FP, he had bad damage on the compressor similar to your exhaust side. FP couldn't do the upgrade due to the damage. Hopefully on yours you can still do you upgrade. intersted to see what the word is.
    Oct 27 2007
    In the lab
    Waiting for Mr. Sean to chime in, I remembered his turbo having wheel damage of some sorts before sending it out to the FP boys...
    Jul 07 2004
    socal
    Quote Originally Posted by dwi_gti View Post
    His center section or housing must have been damaged, because FP just replaces the comressor wheel and machines out the compressor housing.
    Quote Originally Posted by pac1085 View Post
    Well the edges of the blades are bent backwards, almost like something got jammed in there and the wheels just kept hitting it. Either way the turbo is going to get replaced.
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    Mike, are the chunks out of the edges lined up from fin to fin? If something was in the housing, it would have to be fixed pretty well for those fins to hit it over and over and over... OR, the air pressure was keeping something forced to the outside wall of the chamber, but that doesn't sound likely?
    There is an interesting colour gradation from the centre of the fin towards the 'torn' edges.... I guess we'll never know... but I would expect a loose 'something' to grenade the turbo, bit just rough the fin edges.
    Can't wait for the update!
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    You probably sucked up some tires balls. that or a small woodland creature. Maybe it got nice and hot and had some cool down issues from track or dyno.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    are you sticking with a .82 a/r?
    glad to see garretts make power even when the exh wheel is so badly damaged
    Dec 20 2007
    1999.5 Audi A4qm AEB
    iowa
    I saw a turbo that looked like that once that had come out of a rx7 that had blown out a apex seal.
    Jul 07 2004
    socal
    Quote Originally Posted by B5Burn View Post
    Well doesn't doesn't take long to do damage like that while the turbo is spinning at 150,000 rpm.
    Quote Originally Posted by ThirdStrike View Post
    Depends. If its the HTA I will,but if I jump to BW it will most likely be a different size a/r.
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    When will the new turbo and manifold go in? Are you going to have this repaired and then sell it or is it even worht it? Can you save this as a back up in case something happens to the new turbo?
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    hmm. looks like something definitely got in there. most likely you werent paying attention at a track day, swerved into the other lane, and your engine happily ate an entire honda. its understandable, since your turbo is bigger than a b16
    ive seen this many times with compressors, but not with the turbine. i would say do a compression test to make sure if it did go through the entire engine, it didnt mess up the valves also. one thing that also comes to mind is possibly a piece of welding slag broke off the inside of the manifold and did the deed. i look forward to seeing you achieve BAFT or BAMFT status soon. peace.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    damage like that can only be caused by debris
    Jul 07 2004
    socal
    Quote Originally Posted by B5A4Kevin View Post
    I always check the compression, did it before the day I ran 10.5. If the CR was bad I dont think the car would have made the power it did on saturday.
    Dec 11 2006
    Boston
    Just get the s366
    Stage 3+ RS6's
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Get off your high horse.
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    More like get off the airplane, haha.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Jan 25 2006
    A4 2.0T
    MD
    Good luck, FP is kinda funny when it comes to repairing BB turbos.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Does the turbine housing have any damage? Good thing you pulled it out now so it didn't grenade itself down the line due to an unbalanced wheel. Not bad for 4 years of use on the track and dyno.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jul 07 2004
    socal
    Quote Originally Posted by Nebone View Post
    Dont see any damage on the inside of the housing. I think the damage happened long time ago, causing the edges to bend back and then over time ate down to what it looks like now. The boost curve and power band hasn't changed since 034 rebuilt the engine and retuned the car almost 2 years ago.
    If FP isn't willing to replace the exhaust wheel during the HTA rebuild, I will just end up going straight to the twin scroll setup. I sent pics of the turbo to FP and Geoff at Full-race, already heard back from Geoff and still waiting to hear back from FP. So either way something will be going back into the car after the cage is finished.
    Jan 25 2006
    A4 2.0T
    MD
    What did Geoff say?
    Jul 07 2004
    socal
    Quote Originally Posted by Don Supreme View Post
    What did Geoff say?
    His reply
    that sucks, sounds like you are going to need to get this twinscroll stuff going soon :)
    97 A4 2.0TQM
    Rochester, NY
    I hope full-race doesn't start selling B5 twin scroll manifolds... lol
    Jan 25 2006
    A4 2.0T
    MD
    Don't worry... I am sure it won't be cheap! ahha.
    Jul 07 2004
    socal
    When is anything new and worth buying "cheap"?
    Jul 07 2004
    socal
    Well heard from FP, cant fix it so if I want to HTA I have to buy a new CHRA or buy a whole new turbo. So at this time things are up in the air as to what I will do next. The GT35r will most likely just end up going back into the car till FR is ready to build me my custom twin scroll setup.
