Results 1 to 8 of 8
    Senior Member Three Rings gullatec's Avatar
    Sep 10 2008
    baltimore, maryland
    Gas Pedal Sticking
    Yesterday I get into my car and I try to give it some gas and i felt more resistance than usual. I had to press down quasi-hard and it free'ed up, but I have to do that most of the time I give it any gas. Should I just shoot some wd40 up there? Has anyone else had this issue?
    brandon
    USP CLUB MEMBER #119 | dolphin gray | 6SP | UNKNOWN TUNE | TT225 (sitting in a box) | podi | cupra-lip | 6000k Fogs | 20% tint | slow
    Currently: Stage 1ish
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: Gas Pedal Sticking
    Quote Originally Posted by gullatec View Post
    yeah, lube it up. also make sure that the floor mat isn't in the way or hitting it at all. If that doesn't help you might be looking at a bound cable (assuming we use a cable, thats what my saab used).
    Dec 06 2007
    do it before u drive and while the engine is off pump the gas after lubing it to insure it doesn't stick and that the lube sinks in. Do it before it gets stuck at WOT.
    -Kirk
    BetaAlphaTau Member #58
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by widgget View Post
    theres no cable, theyre electronically controlled now.
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    could be a bad TB, i would try to vag and do a TB alignment.
    Jun 08 2008
    Calgary AB Canada
    Quote Originally Posted by vdubstreets View Post
    if its physically sticking? i dont think so
    Sep 10 2008
    baltimore, maryland
    should i just use WD40?
    brandon
    Dec 06 2007
    wd40 will work for awhile but it's not a lube it's a solvent.
    -Kirk
