Results 1 to 2 of 2
    Veteran Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant, '06 Toyota Tundra
    San Diego, CA
    smell of fuel in the cabin when under boost, is this potentially a problem?
    the reason i ask if it is a problem is i found a threat about someone having a similar problem while sitting at a traffic signal with the climate control on. the reason i didn't bump that thread is for two reasons: i don't have problems with the weather strippings in my engine bay like the others in that thread did; and the odor of fuel is only present seconds after boosting.
    so my question is what can cause this? my initial thoughts are the seal between the intake manifold/head, maybe my injector seals, and maybe my fpr seals. anything additional i should look at? it may be worth mentioning i have the old style new south performance gasket. i already re-installed it 2 weeks ago, this time with a stronger, gasoline resistant gasket sealer. maybe i'm set on it being the intake manifold gasket and that's not the problem. any suggestions, tips, or methods for testing would be greatly appreciated.
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/AWE DTS/17" Enkei/Bridgestones
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    Rieger RS4 bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
    May 09 2007
    aeb 2.0bt, 00 bagged 1.8, 93 s-10
    jacksonville, nc
    Re: smell of fuel in the cabin when under boost, is this potentially a problem?
    i just replaced my turbo-manifold gasket, turbo gaskets, and turbo-cat gasket and smells are gone.
    test pipe is gonna do it too
