Results 1 to 13 of 13
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Help programming key with vag-com
    Hey guys I need some help with programming my new key in vag-com. I've used the following steps listed below, my probloem is that when I go to change the channel to "01" or "21" to enter the new value of 1 it just says error and I can't use those channels. Is there another way to try and program the key? BTW this is my only key so I can't use the two key method. Also this is on a 2000. Thanks guys
    Remote Matching
    For this procedure, you must have
    1) VAG COM
    2) A laser cut key (just one is "needed")
    3) Up to 4 compatable remotes to program
    Procedure for matching remote controls to most VW & Audi vehicles:
    Under "Select Control Module"
    "Select"
    "46 - Cent. Conv." or "35 - Cent. Locking" (depending on year and make/model)
    "Adaptation - 10"
    First enter channel "00" as this will set all settings back to factory.
    Enter channel "01" (Again "21 depending on make/model).
    "Read"
    2010 Brilliant Black/Magma Red S4
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Help programming key with vag-com
    http://www.ross-tech.com/vag-com/car...-matching.html but I guess you've already been there.
    Just keep playing around with the codes as obviously you are not inputting the right one.
    Do you have the full version of VAGCOM or just the shareware version?
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by CONTROL ONE View Post
    I have the full version , and i've been putting in the right codes it just won't allow me to select channel 01 or 21 at all it has a error, there for i cannot set it for the new key.
    Btw shout out to scott for helping me out big time
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Just do it the old fashion way. Here is the write-up on AW http://www.audiworld.com/tech/misc.html
    I've done it several times this way, no need for VAGCOM.
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by HighDesertAudi View Post
    Thanks but as you can see in my first post I only have one key and not two do it the old fashion way
    Mar 09 2005
    NorCal
    My bad, I've tried using the VAGCOM method and couldn't get it to work either.
    What I'd do is buy a blank off of ebay (not the whole flip key, just the regular key) the dealer will cut it for cheap, than put that one in the ignition and use your flip key in the door.
    Previous Audi's
    Jan 14 2008
    Carlisle, PA
    That way would end up costing more than just the $60 dollars the stealership charges to program it. I'll just have to deal with using the key to unlock until i get it to work someway
    Mar 09 2005
    NorCal
    No you can buy the blanks off of ebay for less for $10 (http://cgi.ebay.com/ebaymotors/AUDI-...Q5fAccessories ) and the dealer only charges like $10 to cut the key.
    They will cut it for you and they can't charge you to program it because it's just a spare.
    Previous Audi's
    Jan 14 2008
    Carlisle, PA
    $10? Man I'd like to know what dealer you go to. the dealer closest to me has to send them out so i can't just get them cut anyways
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by espo4442 View Post
    I've been able to reprogram a key with just one key in the door lock and not the ignition. Worth a try maybe.
    08 S4- Stock SOLD
    Jan 14 2008
    Carlisle, PA
    Quote Originally Posted by mholme View Post
    And how did you do this?
    Jan 29 2007
    08 S4 00 S4
    MD
    Manually lock the drivers door with the key you are trying to program, then press the 'unlock' button on the remote ONCE only. Then with the key still in the drivers door, unlock then lock the door again. Take the key out and see if the remote works.
    08 S4- Stock SOLD
    Jan 14 2008
    Carlisle, PA
    Nice, I would have tried this but my friend found my other key haha o well I got it all worked out now. Thanks tho
