Results 1 to 4 of 4
    Active Member Two Rings spinner's Avatar
    Oct 28 2008
    HK
    Help ! Backup system light came on !
    Hi guys ! i need some advise. The backup system light for the transmission came on for my B5 (P.R.N.D.3.2.1 light all came on on the dash) i did a shut down on my engine and restart, its back to normal. according to the manual it says need to bring the car to the dealer. may i know whats the problem ? screwed gear box ? and i realise sometime when i turn on the power while waiting for the beeping sound all this lights came on and sometimes don't ! but once i start the engine its all back to normal..... pls kindly help.....
    981CGTS, Cayenne Turbo, '22 A4 Allroad
    Chicago 'burbs
    Re: Help ! Backup system light came on !
    Quote Originally Posted by spinner View Post
    You can check the TCU for water damage/corrosion to the connector, you can check the connector on the trans for corrosion.
    There are many threads on this topic here and on AW.
    2014 A4Q Red w/ black optic black interior
    Oct 28 2008
    HK
    hi... thanks for your help ! where is the location of the TCU then ?
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    remove passenger kickpannel and lower inside door molding
    pull up carpet
    It's located in a plastic box under the passenger's feet.
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
