Results 1 to 4 of 4
    Deactivated One Ring
    Dec 10 2008
    socal
    DICE ipod integration kit
    has anyone installed this? I'm curious to know the set up after it's installed, ie. where the ipod cable comes out if the unit is installed behind the radio.
    thanks
    Nov 04 2006
    05 S4
    LI, NY
    Re: DICE ipod integration kit
    Yeah I did mine....I ran the ipod wire which isnt very long straight towards the ebrake handle and then had it come thru that compartment under the armrest on the B6. I dont think you have that....it would be behind your cupholder??? Or you could run it accross into the glove box like many do.
    Set-up...mine gave me some grief so I recommend leaving the radio partially out and try it so you can set up the switch on the unit the way you'd like.
    Dont forget the ground wire which I attached to the radio itself on one of the small screws on the top.
    And...after all was done...it doesnt work exactly the way I'd like.....going thru playlists and artists sucks!!! I just leave my ipod on shuffle and just go thru the songs manually.
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    I did mine in 15 minutes. I ran mine to the top shelf in the glove box and leave it on shuffle. It plugs into your CD changer on the back of the radio. It will only fit one plug, so it's easy to figure it out, run the cable to the glove box, push the radio back in.
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Established Member Two Rings DucatiTorrey's Avatar
    Aug 16 2011
    2004 Subaru Forester XS, 2004 A4 Avant USP
    West Michigan
    I'm planning on setting mine up here in a few weeks. Heard if you hook it up through the SAT in the back, no taking out the radio, easy as pie. Ill post some pictures.
    2004 Arctic White A4 Avant USP 6MT
    *WTB: B5 Spring Seats / Perches*
