Results 1 to 6 of 6
Thread: Key fob Q
    Dec 06 2007
    Key fob Q
    My key fob doesn't fold right and is busted anyways:
    My friend randomly gave me a new key fob lol and it has its own blade that has been pre-cut can i program it to work this way or do i need to punch my blade off the broken fob?
    -Kirk
    BetaAlphaTau Member #58
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Re: Key fob Q
    Quote Originally Posted by AudiA4Turbo22 View Post
    Well #1...you cant use it...because first it would have to have a New immobilizer (which is a chip inside) so it can be programmed on your car. then you would have to get a fresh UN-CUT blade. you cant just take any blade and use it on any car. go to Audi buy the blade and have it cut by them so it can fit your car. if any body could take any key and program it and could use it on any car..your car would of been hi-jacked by now..
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Re: Key fob Q
    Seeing people having done the B7 key fob mod, this should be no different. You do need a vag-com to program the new key to your immobilizer IIRC, the transponder chip from the old key (to put into the new key fob) and the original key blade to put onto the new fob. Search for the B7 key thread and there are instructions in there.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: Key fob Q
    Quote Originally Posted by gdawg'05a4 View Post
    if you are pulling the chip from the old FOB and putting it into the new one no vag programming is necessary to make it start your car, your just putting your chip and blade in a different plastic housing. you might however need vag to help code the door lock buttons to your car.
    Dec 06 2007
    Re: Key fob Q
    thanx guys
    -Kirk
    May 03 2005
    Boston
    Re: Key fob Q
    Quote Originally Posted by widgget View Post
    Hmm, makes sense. I just remember reading something about vag-com and the immo. I know you need vag-com for something
    EPL S2 + TCU
    Previous Cars:
