I'm not usually the one to give a bad review about a product, but damn, I can't hold this one back. So apon my install of my BT kit, I also ordered a Blinktek heat shield to go with my open air filter. Let me just say, this thing fell apart after I tried to adjust the shield twice. (pulling it out and putting it in a few times.) The rubber lining, all fell off on the back side, and the reflective foil that was probably glued on to the aluminum shield started to peel off.... Not only that, even after I fix all of these flaws, I try to fit the shield on there properly and securely. Guess what? It doesn't...the heat shield was touching the turbo and the test pipe, NO CAN DO. Either you let it rest against the turbo and testpipe to fit securely, or you can push it further left towards the intake area where it will just wobble around. Oh ofcourse, there is one little whole with the smallest zip tie in the back so you can secure this heat shield with.
Sorry Matt, but for 80-90 bucks and the amount of labor I put it in and trim the damn thing to work...I could have done this shit myself...
