Results 1 to 7 of 7
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Best way to get goopy coolant/oil mix out of system?
    My entire coolant system is filled with this goopy crap. I fixed the problem that was causing it (oil cooler), but I can't put it all together until I clean out the lines. I thought that I would be able to just shoot it all out with the hose but it's a lot thicker than I had expected and holding a hose onto one of the coolant lines to push it out doesn't do much.
    Somebody told me I could get something that attaches to my coolant reservoir and will pressurize it all out, but I don't know if that will be strong enough still.
    What would a shop charge to clean out the system?
    Would the part that attaches to my reservoir be a good way to go?
    Is my best bet just tearing it all apart and cleaning each section by itself (lack of time is forcing this to be my last resort).
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Re: Best way to get goopy coolant/oil mix out of system?
    I would fill her up with water run her till she’s hot then flush her being very careful not to scold your self as the heat will make flushing her a lot easier oh and do it a few times.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Dec 05 2007
    You could use some degreaer that is dilluted. The bottle will tell you how much to dillute it for your application. Do a regular coolant flush and run the dilluted degreaser a few times through. Then flush it clean with water. But if anything goes awry, I am not held liable .
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    You might have to take out your Tstat so you be sure to get it all out.
    Veteran Member Three Rings v1nyd's Avatar
    Jun 15 2008
    Long Island NY
    Quote Originally Posted by ILoveT View Post
    Yeah I noticed when I did my timing belt so much more coolant came out when I got up to the water pump and thermostat part than when I just drained it from my radiator. I took two whole gallons after that but when I do a regular flush from just the plug on the bottom of the radiator only a little more than a gallon comes out.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    1 Pull the thermostat, 2 go to napa and get some radiator flush, 3 run the car for a bit, 4 let it get nice and warm, 5 drain old shit out, 6 fill with water and put t-stat back in, 7 let it warm up to operating temp, drain water, 8 if it was clear fill with g12 mix if not fluch till it is
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Aww man, it sucks that I have to run the nasty stuff through my brand new oil cooler... oh well, that sounds like a plan.
    Thanks for the help, I'll post back here if anything goes wrong.
    because racecar.
