Results 1 to 13 of 13
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Audio Gurus,.. need help!
    Ok I have 2 kicker CVX's dual voice coils each four ohm. I also have a memphis 1000.1 amp. It puts out 1000 watts at 1 ohm. I had it wired funky, I'm not sure if it was at 4 or 2 ohms. But I was just trying to wire it at 1 ohm and followed this wiring diagram
    http://www.rockfordfosgate.com/rftec...2&woofer_imp=4
    It sound horrible. I cant tell if it is louder but it does not rattle my eardrums anymore and it does not have nearly as much bass as it did. I'm very disappointed. I'm pretty certain that I wired it right, but I could be wrong. It sounds like the subs are rattling if that makes sense. I know a lot about audio but I don't know what's going on. I tried changing the polarity and that didn't make it any better. At low volumes it is decent but as soon as you turn it up all you hear is loud vibration, but they are not coming from the car. Or atleast that's what it sounds like. There is no deep bass at high volumes. What's my problem?
    Sorry If i blabbered on and repeated myself but it's hard to explain/describe.
    Thanks
    Cameron
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Re: Audio Gurus,.. need help!
    Disconnect all wires and listen to each sub independently.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by actlsub9 View Post
    That's kind of hard since all the wires are hidden in the box and there is only a single speaker line out, positive and negative, and it connects both subs
    Stage 2+
    Jun 13 2005
    Audi
    Quote Originally Posted by ConroeA4 View Post
    Might be a good idea to do. You can double check your wiring, listen to each sub independently, and maybe see if the "vibration" is coming from loose wires hitting the cone.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Senior Member Two Rings 4R!NGS's Avatar
    May 11 2008
    Nassau, Bahamas
    I too have 2 12" kicker cvx DVC 4ohm in my other car. you should wire them both in a parallel which would have the load at 1 ohm. if your amp is 1 ohm stable that is the best way to run it. if not look into a 1 ohm stable amp.
    Oct 27 2008
    Montgomery TX
    When you wire it at 1 ohm the bass is still as "deep" as 4 ohms right?
    Stage 2+
    Jun 13 2005
    Audi
    Wiring it at 4 ohm will give you 25% of the power of it at 1 ohm. The wiring configuration has no effect on the sound other then volume.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Definitely pull them out of the box.
    Chances are you have a Grounding issue. One of your VC are grounding where it shouldn't be.
    Better stop playing that music right away. Pull it out of the enclosure and check your VC wiring. Otherwise, you could end up FUSING the Motor Mechanism SOLID SHUT.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Veteran Member Three Rings tdmopar59's Avatar
    Jun 23 2008
    05 A4q 1.8t 6mt
    i highly reccomned getting a better amp made to put the power you need at 4 ohms if you want it to sound good....
    05 1.8t 6mt | itg filter | bailey dv | UNI flash | USP front | e-codes | stay tuned
    help me buy more parts!! Any work you need in SE PA area on your car or with construction let me know!! (PM me)
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    amp is at 1ohm resistance, and you have two subs running at either 2 or 4 ohms. whether or not they are wired in series or parallel could make a big difference, but straight off the bat i can tell you that you are running into massive power loss going from 1ohm to a dual 2/4 ohm setup. if im correct, just going from 1ohm to a 2ohm sub you lose half the power. correct me if im wrong
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    def check your grounds..they will do some wild things to sound systems. last time my subs rattled, they were blown but that is probably not the case for u. like stated above, check all ur connections, i would pull the wiring for one sub and run one with the proper +- and see how it sounds.also check the gain on the amp, u may be over powering them but again that probably is not the issue.. .good luck
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Mar 11 2008
    B7RS4 & e46Ms
    Sounds like you've got them wired out of phase...
    As said above, pull them out, and check the wiring individually...and listen to them individually...
    FRRG AZ Ring
    Oct 03 2008
    2005 A4 3.0 USP 6MQ
    Chicago IL USA
    Yes - do check to see if both woofs are in phase. Disconnect your woofs from the the amp and try connecting/disconnecting a D-cell battery across the woofers. You will hear a click. If you can see the cone, you will notice that it moves out (or in) slightly when the battery is attached, then moves back to 'normal' rest position when the battery is disconnected. If the drivers are in phase, the cones will both move in/out together. If one cone moves in while the other moves out, they are out of phase. If this is the case, one woof is cancelling the sound produced by the other. You know this is not good!
