with or without the RS4 wheels
2001 Audi S4 6speed
Silver Ext.
Black Leather
151,250 as of 11/26/08
MILEAGE WILL CONTINUE TO GO UP THIS IS A DAILY DRIVER
Car is in Great Shape
Turbos Spool Perfectly
Recent Maintnence
Timing Belt Service
Cam Tensioner Seals
Valve Cover Gaskets,
Aux.Water Pump
Battery
Rear Brakes
Rear Wheel Bearings
New Right front CV Joint and Boot
New Left Front CV boot
Coolant Temp Sensor
Zimmerman Cross Drilled Front Rotors
Mintex Pads
New Coolant Expansion Tank
Neuspeed Springs
Yellow Fogs
Car was completely stock when i got it.
Car needs a thermostat.
Doesn't overheat.
Mechanic says its stuck closed
and not letting coolant flow to heatercore
Hence the heat not working.
Car with RS4 wheels...
