Results 1 to 6 of 6
    Senior Member Three Rings zbrock06's Avatar
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    How do you remove the breather hose from the T (picture) NOW NEED HELP WITH NEW!!
    I can reach my hand in there without taking the manifold off and i just can't figure out how you take it off. I can't get it to just slide off, does it just slide of the T fitting, it cracked towards the top and it needs to be replaced. I searched and found the picture but nothing about how to remove it. I figured it would be held on by a one time use fitting but it's not.
    thanks in advance.
    USP CLUB MEMBER #94
    Senior Member Two Rings abradley's Avatar
    Mar 12 2007
    02 A4 3.0 Quattro
    Virginia Beach
    Re: How do you remove the breather hose from the T (picture)
    i dont remember exactly when i took mine off but i think there are two tabs you need to press in and then it slides off. i opened the hood and stuck my hand down which was super hard to get to and apply the pressure but it finally came off
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    There is no tabs on the hose or the T-fitting
    USP CLUB MEMBER #94
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Quote Originally Posted by zbrock06 View Post
    Your right there are no tabs. Mine ripped a month ago and I had to replace it. Like you said there isn't any way to get to it with out taking the intake mani off. Once off I had to cut it off. I couldn't find any other way to get it off.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    thanks, i guess i will cut it off. Was your replacement hose rubber or metal. I ordered one from the dealer and it's metal and i think they ordered the wrong part.
    USP CLUB MEMBER #94
    Oct 15 2006
    '04 USP A4 1.8TQ
    Stamford, CT
    how do you get the new one on? I have tried heating it up in boiling water and putting it over the t-fitting but it still won't even come close. My old one looked like it had a flange and the new one is a straight tube.
    Jrau13, how did you get the new one on?
    USP CLUB MEMBER #94
