Results 1 to 7 of 7
    Senior Member Two Rings silvertze's Avatar
    Oct 22 2008
    2011 Jet Black 135i (M Package)
    Montreal
    Steering wheel tightening problem
    So we just had a big snowfall and I'm glad and all, however my car doesnt seem to like it.....I think. Is it normal that my steering wheel is firmer? It loosens up whenever the wheels are spinning, however when im stopped its as if there is no power steering. Is that normal?
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Re: Steering wheel tightening problem
    Well if your wheels are buried in snow the wheel may not turn as well. Not sure what you mean by big snowfall. I'm guessing when you are hitting the gas and turning the wheel the moving wheel is digging into the snow kind of pushing it away and making it easier to turn your steering wheel.
    If youre not in snow it could always been your power steering fluid but I don't know about that one.
    Oct 22 2008
    Montreal
    I only mentioned the snowfall because I thought i might be some sort of audi factory thing where the steering becomes firmer to avoid problems. The thing is now, even on plowed streets, its unresposive when the car is standing still, for example, waiting at a red light. However as soon as im driving i have complete control.
    Senior Member Two Rings Wanted's Avatar
    May 17 2007
    A4 Quattro, vert Z, Jeep XJ
    Louisville, KY
    I would pull into a gas station or carwash that has no snow under the canopy and see what the resistance is when you turn the wheel. A couple things could be going on:
    1) Power steering fluid could be contaminated with moisture and the weather is effecting it
    2) you could have slush and frozen goo built up behind your wheels and it's interfering with your tie rod assembly
    3) the amount of snow could be putting undue pressure
    Do a visual check on the fluid and the components and get back to us and we can help from there.
    Good luck with it.
    Matt
    1 more red A4, 3.0, 6spd Quattro...
    Now with a "free" Imola B5 S4 6spd
    Oct 22 2008
    Montreal
    So ive checked all my fluids, ive even gone through a car wash to wash off the snow. Point being it its unbelievebly tight to steer, its as if I have no power steering when the car isnt moving. Ive even put winter tires on yesterday but I dont think it has anything to do with the tires. Is there a motor for power steering? any fuses i should sheck...i dont have any warranty so im trying to avoid a big repair bill. Thanks in advance
    Oct 22 2008
    Montreal
    anybody?
    Oct 22 2008
    Montreal
    So i talked to a mechanic friend of mine he said it could be the buschings?
    Does that sound likely...is that expensive?
