Results 1 to 2 of 2
    Registered Member Two Rings
    Dec 02 2008
    canada
    My codes need help
    i look a little bit on the forum but is there a specific place to check all my code
    here's some i check with my friend vag-com
    edit i found some
    p1676:malfunction light ............1 led plate is down and the other one is flashing like a party lol and my right brake light do not work maybe this is why ??
    p1459:exhaust temp sensor........egt
    p1690:epc light ???
    p0441:evap emission control sys incorrect purge flow ......what that mean
    can someone tell me what are does mean ?
    and what part i need to change
    thanks
    and btw i am new on the audi
    it's on my 2001 s4 2.7t tiptronic stage 2
    so for now i know i need to change the 2 led plate light and the right brake light but do i need to change the evap sensor and egt too ?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: My codes need help
    If you cut and paste those codes into the search, forum here as well as on audiworld, you'll get some possible fixes. You need at least a driver side EGT sensor.
    08 S4- Stock SOLD
