Results 1 to 14 of 14
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    Stereo Reception
    I know, I know.....been done to death.
    Problem is I can't find my answer and I think it's different enough to warrant another thread.
    1. FM is great. Can pick up a lot of stations. AM blows. Nothing but static. I get static on FM only when I turn on my defrost just like everyone else and I'm sick of it and I want to get rid of it.
    2. I know I need a power antenna adapter. Can't find one that works. I have a Pioneer DEH-P770MP and on the back of the stereo there is a coax connection on the back of the stereo. Just like OEM. There is not a connecton to fit that RCA look a like connector. Am I new? Can I pull that connector off the adapter and get a coax connection?
    3. Rear speakers don't work....but that's a separate issue!
    Any help would be awesome! Thanks guys
    14 A4 allroad - stock
    05 allroad 2.7T Stock
    Apr 25 2007
    millersville, maryland
    Re: Stereo Reception
    What system did you originally have in the car? annnd.... did you just use a harness?
    Feb 23 2007
    Burlington
    concert. Nope.....no harness. Cousin installed it for me before I knew all the quirks with Audi. Cut the old one's off and spliced 'em together. As trailer park as it gets. I'm actually thinking of changing it back so it's somewhat factory again......
    Feb 23 2007
    Burlington
    bump.......
    no one? If I'm not making sense, then by all means fire away, but no one has any comments?
    Feb 23 2007
    Burlington
    really? Someone has to know the answer to this......
    Feb 23 2007
    Burlington
    dammit. I guess no one wants to help. I'll see if I can figure it out, I guess!
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Audi uses a booster for its radio antennas. There is a separate booster for both AM and FM. I am not sure of the exact wiring. But I am willing to bet, that by taking out the stock stereo, the relay to turn those antenna amplifiers on, is not on. You need to get a wiring schematic and look it over. Audi runs their antenna through the rear window glass defroster on the A4 if I remember correctly. On the avant it is through the antenna mast.
    Feb 23 2007
    Burlington
    ^^^ I'm aware of all of that....thanks!
    This is what I'm doing.....I'll post if it works or not.
    http://www.crutchfield.com/p_12040VW...r.html?tp=2569
    This will allow me to use the amplified adapter and still connect it to my head unit.
    Hopefully it works!
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    yes that will help substantially
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    I had this problem for well over a year, and yesterday I decided to install that adapter from Crutchfield. And I went from no radio to having radio so I'm happy, but the reception still isn't at 100%. IF you find anything else that helps with the reception post it up!
    2000 Audi A4 2.8L Quattro Sport - Volcano Black
    Mods: 18" A8 Rep's, Ebay SS & Strut tower bar, PureMS Snub mount, K&N, MAF de-screened, H&R sports, STERN power ring & diff mounts, Cupra Lip, DEPO ecodes, Unitronic flashed ECU, Magnaflow
    Senior Member Two Rings stubbs's Avatar
    Jul 29 2008
    Utah
    If your windows are tinted, I've also heard that most aftermarket tints don't hurt FM reception, but drastically cut AM reception.
    Feb 23 2007
    Burlington
    Ok....I know it took a while but winters in Ontario blow chunks. Today was the first day I could get this stuff done without freezing my stones off.
    2 things.
    1. Alternator Whine: I know it's a bit of work but this method works flawlessly. Not a hint of sound when RCA's are grounded this way.
    http://www.caraudio.com/forum/showth...ground+rca%27s
    2. Static from Defrost? Crutchfield Powered Booster works perfect. Wired it into the Accessory line and it works perfect. Stations were all I heard was static are crystal clear now. I'd recommend this to anyone.
    For me.....this totally solved the problem. Now onto an Avic N4/N5
    Veteran Member Four Rings black99.5a4's Avatar
    Jun 26 2008
    00' Noggy Stg2
    Middle of a Cornfield, PA
    i've been told the static with the rear defrost is because of the FM booster going bad. It is in the rear c pillar next to the rear window. when you click the defrost on, it interfers with it.. because mine only does it to 1 radio station that i barely listen to, i'm not too worried about it. (it only does it on stations that are weak to pick up signal)
    '00 Nogaro S4 - TIP, Ebay turbos, Ebay inlets, Ebay stage 2 tune, OBX manifolds, OBX exhaust
    For all your OEM Audi needs
    Feb 23 2007
    Burlington
    Could very well be.....this may be an alternate solution if it's too much work to fix the original.....
