Originally Posted by
tj4891
Hey everyone, im a new a4 owner and new driver... 16 years old.
Silver 1999 A4 1.8T Quattro Automatic Transmition no current mods
I have a few questions.
I am looking to get this muffler
http://vibrantperformance.com/catalo...463ecd53bf2d6f
Im not sure what the Audi inlet size is but the muffler is 3". If the car is not 3" can the muffler shop make it work when they install the muffler or do I have to choose a muffler with the same inlet size?
My front door speakers are blown. I do not have the bose sound system so they are 4" speakers. Is this the only size I can install? I have read off of here that I must custom install them because of the bolt pattern. Is this hard to do? I would rather save some money and do it myself, but if it is too hard I will just take it to Car Audio.
I was thinking about niteshading or tinting the tail lights. Is this recomended? What about for the head lights? Both?
When I am cruizing usually down a hill not accelerating it sounds like someone is dragging a small chain on the ground along side the car. Is this normal?
And last I have been told I need to replace my fan belt, a.c. belt, and water pump belt. Is this an easy/quick process?
First off, welcome to Audizine. Be sure to make yourself familiar with the FAQ sheet and know that the
search button (found at the top of the page) is your freind. It can save you from being flamed in the future.
Vibrant has one of the sweetest sound notes when it comes to exhausts, but the one you posted in the link is overkill for a stock k03 turbo (3 " piping to dual 3.5" outlets). Some say that 3" alone is overkill for the stock turbo, as that is the same diameter used for big turbo applications including the GT3582r. But there are a few whom run that set up all day and love it. I myself have 2.75" exhaust system on the stock turbo flashed/chipped. I would recommend to stay between 2.5"-3" (but if you plan on going BAT/Big *** Turbo in the future, then get the 3" all the way through).
I can not recall about front speakers. But you can stick aftermarket speakers in there. You would just need an amplifier to power tham. And when bolting it up, I believe the way the mounting is designed, there will be one bolt that will not be able to be fastened. So it will be held on by either 2 (I think it is 2) bolts instead of 3. You can place some foam behind the speaker in case of rattle that may occur due to that missing bolt.
You can tint the tail lights. There are many whom do it. As for the headlights, if you want to tint those you should use Lamin-X (google it).
No, it is not normal to hear the noise of a chain being dragged across the ground as you cruise down a hill. As for the noise, I have no idea. Where is it coming from (on the chasis)?
As for replacing those parts that were recommended fixing, you will need to wait for another to chimme in. I have never attempted myself.
