Results 1 to 10 of 10
    Veteran Member Three Rings CTUltrasport's Avatar
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    Engine Block Replacement
    Hi Everyone,
    It has been a while since I was on last, but a recent issue presented itself and I wanted to see if anyone has either experienced this or heard of it..... check engine light has popped on intermitantly on my '04 3.0 and each time I turn my ignition off then back on, it is no longer lit up. Take the car to Audi for other routine maintenance and tell them of this....in their further research, they find that there is a missfire on the #2 cyl....apparently they tried a bunch of different things and were unable to stop it from happening....said it seems to be a possible coolant leak into the #2 cyl causing the issue.... the call I get the other day was that they are replacing the engine block and just ordered it through Audi... thankfully this is covered by my extended, but the project sounds quite extreme. Has anyone heard of this or experienced it?
    2013 Audi S4
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    Re: Engine Block Replacement
    anyone?
    2013 Audi S4
    Senior Member Two Rings mtxsho93's Avatar
    Sep 20 2008
    93 SHO, 02 A6 2.7T 6MT
    South Jersey
    They are replacing just the block or the entire engine?
    Ian
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    as far as I know it is the engine block. His last VM to me was "your engine is on order" which i am assuming he meant the block. Odd right?
    2013 Audi S4
    Sep 20 2008
    South Jersey
    I can't speak for all dealers or shops but if this is a factory warranty claim, I would imagine that they ordered a complete crate engine to swap out with your existing (bad) engine. Most dealers don't have the time, inclination, or want to accept the liability that comes with rebuilding an engine. I also would not be surprised if Audi wants the old engine back for analysis purposes.
    For what it's worth, swapping an engine isn't as extreme as it sounds. It's just a few nuts and bolts and a lot of wiring connectors and different hoses and lines. :)
    Ian
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    and a new engine, so I guess I shouldnt be complaining lol. They gave me an '08 3.2 with 1,000 miles on it till I get mine back so it isnt all that bad :-)
    2013 Audi S4
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Which shop did you bring it to audi fairfield?
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    new country in greenwich? Your car isn't black, lowered, and de-badged except for the "quattro" is it?
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Sep 28 2008
    Boston, MA
    just kidding, just saw it was silver.
    Current: ISO RS4
    Jan 25 2007
    2005 Audi TT
    Greenwich, CT
    Quote Originally Posted by Charlescrs6 View Post
    Lol, silver Ultrasport debaged and it is somewhere in the lot at New Country ,lol.
    2013 Audi S4
