That's not correct. Using hot water will just get it to warm up and open the thermostat faster. When you open the t stat it will circulate coolant through most of the passages. If you use cool water it will just take a while longer.
You want to flush it with straight distilled water several times. I did mine 4 times and it's still brown.
I bought a ton of it at the grocery store. I used about 1.5 gal per flush. If its just straight water just let her sit and run w the heat up and fan on low for several min the pull the clip on the temp sensor and stand back with the motor off. It'll pop from the pressure and then you can cap it off, fill and repeat.
