    Registered Member Two Rings
    Jul 09 2008
    Napa, CA
    ABS, Speedometer issues
    Okay, well to start off, I had all my front control arms replaced both left and right, and to be my luck when I got my car back from the shop they told me my ABS light is on and they needed an hr of diagnostics to see what is going on. Well my car had no problems with my ABS, what could I check just to make sure everything is connected right, or if its simply a sensor? Oh yeah they told me they quick tested the ABS unit and it was working fine. They said they couldn't erase the code as it would come up again. Now my next issues is that about a month ago I tried to get my speedometer replaced(mine was crapping out and LED's were dissapearing) well needless to say when I unplugged it and plugged it back(the other also had burned LED's) it turned on all the lights in the center of the speedometer and made them flash(the lights that tell you if you have a light bulb out, or wiper fluid is out ect.) and now they wont stop flashing. I know its that I unplugged it, how do I fix that? Appreciate any input. I do plan on going back to the shop as they had to remove the ABS to get to the right mount in order to replace the control arms. Thanks
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Re: ABS, Speedometer issues
    Sounds like you need a new speed sensor. We have some in stock. Quite possibly one for your car.
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    ^^^^^ Hahaha Wtf!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Mar 15 2008
    A few Audis
    Independence, MN
    Oops I read it wrong, I thought he pulled the speed sensor and it went haywire on him. Speedometer ftw
    Registered Member Two Rings RSMESS's Avatar
    Nov 12 2008
    01 TT Quattro (180)
    bel air, maryland
    hey the same thing happened to my car today. did anyone get back to you on that?
    01 TT Quattro (180) Absolutely STOCK
    "Drive Safe"
