Results 1 to 7 of 7
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    manifold and turbo rust
    hey guys im about to install a new K04 and i really hate how my k03 is rusted to hell, so i dont want my new k04 and manifold to be all rusty. what can i do to stop this? is there any type of engine coating like VHT sells some good stuff that i could spray on there to prevent rust on the new parts? thanks so much.
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: manifold and turbo rust
    the rust isn't a big deal if it's just atmospheric moisture. completely normal. if you are soaking the thing in water, then that's a different story.
    but you can always get it ceramic coated. plenty of options out there. Swain is the most known for their manifold/turbo/dp coatings.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    You can try blasting it with walnut shells?
    Check your PM.
    Feb 22 2008
    Richmond, VA
    hmm walnut shells hahaha
    i know its completly normal but rust just bothers me and when i look at my engine i want it to be all clean and brand new looking still.
    USP CLUB MEMBER #97
    Unitronic tuned RS6
    Feb 26 2006
    Earth
    yes walnut shells...its a media used in blasting.
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Cast iron and steel will rust with humidity, and will also rust with heat. You can coat it, but it is pretty normal. This is why some companies make their manifolds out of stainless steel (turns brown and expands, and sometimes cracks) or inconel (expensive).
    Feb 22 2008
    Richmond, VA
    word guys thank you so much i think im going to coat it with the swain tech stuff that stuff looks great. and it was fairly resonable so that cool. thanks again for your help guys.
    USP CLUB MEMBER #97
    Unitronic tuned RS6
