Results 1 to 10 of 10
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    B7 2.0T Coilovers on B6 3.0
    Like the title says I am looking at a set of coilovers for a B7 2.0T Quattro. I know the B6s and B7s have the same suspension but I just want to double check they will work on my B6 3.0 Quattro.
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    Re: B7 2.0T Coilovers on B6 3.0
    I could be wrong, But I'm going to assume the 3.0 engine is heavier than the 2.0 engine, therefore it might not sit right....
    someone with more knowledge can chime in. :)
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Jul 04 2008
    York, PA
    Quote Originally Posted by tamaneri View Post
    That is my thought as well but with them being coilovers and not just springs I should be able to adjust the settings. Am I right or way off base here?
    Veteran Member Four Rings Styleprojekt's Avatar
    Nov 17 2006
    Salt Lake City
    Depends on the brand, check part numbers on the website...since some companies have general model applications (all B6 A4, all A3 etc), mostly in europe though where they work for 1.9TDI, 2.0, V6's etc all with the same set of coils
    Jul 04 2008
    York, PA
    I tried to check part numbers but I couldn't find any online company who is selling H&R Coilovers and has the part numbers listed.
    Nov 17 2006
    Salt Lake City
    According to this, Street Performance Coil over Kit for example works for all 8E (inkl facelift wich is B7 since they are the same body) for 4 cylinder engines...however 2wd for some reason. I could imagine 4wd is same concept though!
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    wont fit.
    Jul 04 2008
    York, PA
    Quote Originally Posted by romell View Post
    wont fit.
    Care to elaborate?
    Jul 04 2008
    York, PA
    bump
    Jul 04 2008
    York, PA
    wont fit.
    If your going to answer my question could you please provide some insight?
