Results 1 to 2 of 2
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    Oil Feed / Drain, Water send + return for GT3076R in B5 QTM
    I need some help figuring out the best solution for plumbing my new turbo. It is a Tial/Garrett GT3076R and it is going in my 1997 B5 TQM. I want to use AN fittings and aircraft (braided stainless) lines throughout...
    I am uncertain whether I should be using the stock oil feed/water feed + return locations adapted to AN or not I'm presumng I'll need AN10 or AN 12 oil drain, but where/how do you dump this into the pan? punch larger hole, weld an appropriate size fitting or what???
    any advice will be greatly appreciated, thanks!
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    Re: Oil Feed / Drain, Water send + return for GT3076R in B5 QTM
    oil pan adaptor - http://www.atpturbo.com/Merchant2/me...ory_Code=VVWOL
    atp has a lot of the stuff you need if you want to piece the kit, or you can even buy the premade kit from 034 which have everyting you will need for oil/coolant
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
