I have APR stage II with test pipe, 91,93,100 and test pipe file, APR complete exhaust, Forge DV, Zero3Zero motor mount, VAST water.meth kit, AWE boost gauge and APR/Carbonio CAI. Based off of the gauge, (no dyno data yet)I spike to 21PSI boost , and through rpm range it falls to 15-17psi. My vacum @7700 feet above sea level was 12 mmhg on the gauge, I have recently moved to 980 ft above sea level and was holding around 16 mmhg. I recently noticed a drop in mmhg to 21 and that the boost would spike to 16 psi and fall to ten psi. I had no idle issue and the PVC was replaced 3000, miles ago. I used a spray bottle to look for leaks, and found none. I then re-tightened all intercooler clamps and clamps in the circle and this fixed the problem a bit. Now I am @ 20 mmhg, and spike to 15psi and hold to 14psi. No loud noises from turbo, and wrote APR. they said check the N75 valve??? Have no clue what and where that is. Still researching it. So I assuming that when under load the hoses may expanded and leak or expand enough in the drop of pressure. Hell I am at a loss.. Thus the post..Thanks for your help, and there will always be those with more boost, so no feelings hurt
