Results 1 to 9 of 9
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    strange missfire
    i have a 2.7t that missfires bankonly its in a 03 allroad ive replaced plugs, coils, temp sensor, exhaust tempsensor it misses once warm at idle and if reved up while stoped it not felt while driving but i see a few counts in mvb 015 any input would help oh and i swaped the maf from a good running car thanks guys
    Oct 31 2005
    Ashburn
    Re: strange missfire
    What? You might need to rephrase things. Are you saying you have a misfire at idle?
    Or is this a WOT misfire?
    If at idle, those are common misfire's and i wouldn't worry about it. Also did you change you ICM's ? those also cause misfire's
    - Instagram: @Sinister_rs5-
    May 27 2008
    Arvada, Colorado
    the 03 and up dont have icms its a miss while not under load and it triggers the light to flash at times
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    What plught do you have? I had the same problem when i 1st got my S4. The PO had bosh platnums put in and they would miss at idle and sometimes at wot and also cause the light to flash. After replacing them with OEM plugs everything went back to good.
    If that's not the case i would vag it and pin point the cylinder and try swaping coils, if that doesnt help you might have a ECU problem.
    May 27 2008
    Arvada, Colorado
    well it turns out it looks like the t/b has stretched so that bank 1 is off by about a half a tooth, ok the customer is the original owner and the car has 42843 miles nothing on the front of the motor has been apart i went home before i took the crank pully off to check the tentioner but the belt is still tight so i dont know has anyone else seen this before
    Jan 03 2008
    Iowa
    I have seen a belt stretch by a 1/2 a tooth but nothing this low of a milage. Put the cam lock bar to make sure on this.
    If it was a tooth off i beleive it would run a lil rough but 1/2 might be ok.
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by 02alltoad View Post
    Holy Missing Punctuation Batman!!
    I hate it when people post from their Blackberries...
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    May 27 2008
    Arvada, Colorado
    Quote Originally Posted by BITRBO View Post
    i have a moto e6 sorry!
    May 27 2008
    Arvada, Colorado
    its a touch screen phone with a very small keyboard. Now if i had 20 or so min the my punctuation wouldn't be so bad. Now thank you for your input with my problem and the next time i ask for help and post what i have found ill be sure to try to use proper punctuation.
