Results 1 to 37 of 37
    Active Member Two Rings B6quattro1.8T's Avatar
    Aug 05 2008
    Illinois
    Tiptronic shifting when chipped..
    I was wondering when you guys shifted after your car was chipped. 1st gear blows but 2nd and 3rd are great...it just sucks off the line obviously.
    So for those of you that have a 1.8T and are chipped, what rpms do you usually shift when trying to get the max out of the engine? When you race, do you usually just leave it in Sport mode? Thanks guys.
    Currently Modding
    2004 A4 1.8TQ, Brilliant Black
    REVO Stage 1, 710N DV, Apikol Snub Mount, Forge TIP, 20% tint
    What's next?
    Dec 06 2007
    Re: Tiptronic shifting when chipped..
    leave it in tip and floor it, or if ur more technical around 5200
    -Kirk
    BetaAlphaTau Member #58
    Buncha motorcycles
    Memphis, TN
    leave it in sport... computer is smarter than you
    APR Stage 2/AWE Intake
    Dec 06 2007
    ^^haha
    -Kirk
    Buncha motorcycles
    Memphis, TN
    what? it is! It knows the optimum points in the RPM band to shift at...
    Oct 22 2005
    Reppin the Mitten.
    Actually the only reason why S or D is faster then TIP mode is because the tq conv doesn't lock in S and D. So technically... the computer isn't smarter . There isn't really optimal shift points imo, i've tried at the qm, whether you shift right where your power band starts to fall or not, you yield very similiar results. Even TIP mode and S mode have moderate differences. The thing that truly holds us tip guys down is the speed of it shifting, as well as the lack of ability to launch. Sooner or later, one of us will figure it out, and we will take over the 5/6 speed guys...hopefully.
    Buncha motorcycles
    Memphis, TN
    keep dreaming tippy! haha
    actually you would probably beat me, so ill be quiet now........ for now anyway!
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    haha!
    Papachristou, Who is that girl on your new avatar??
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Buncha motorcycles
    Memphis, TN
    a troublemaker! that was my morning email :) (well the top half anyway)
    she isnt even wearing make up there. thats right out of the shower
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by Papachristou View Post
    And just when the time to laugh at FWD people is right!
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    Oct 22 2005
    Reppin the Mitten.
    Its ok, i've seen your video of you launching, and I think it moves quite good for apr 1+. Give us Tippy guys some time, and hopefully by the end of the winter, I'll have something more presentable in terms of tiptronic BT's.
    In the end its who has more knowledge, research, and money spent. Manual guys have to upgrade their clutches and flywheels, we just have to get our tq converters and potentially valve bodies. Which not many has stepped up to the plate for, and even for the people that did, for some odd reason they keep it pretty DL.
    Buncha motorcycles
    Memphis, TN
    yeah now is the best time to be laughing at FWD/RWD people!
    vinny, i guess since i have every freaking mod 1+ can have except w/m it goes OK... whenever things turn around im either going to try that new ecode gtrs greg is working on or build my motor and do a 3076..... then we will see how she moves along
    whats all that TQ and VB work run? a good clutch with install can easily run $2k... i know i spent about $700 by the time it was said and done with new bolts, spline drive sockets from snap on, beer, aspirin and bandaids.....
    Registered Member Two Rings
    Dec 01 2008
    NM
    I'm curious if a chipped tip car will shift later, ie 'in the red', since most chips remove the early rev limiter. Is this the case?
    Buncha motorcycles
    Memphis, TN
    im not sure but i thought there was some kind of TIP chip? something for the tranny to change its shifting?
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    you know what 1 is slacky and slow..
    but the best is when im in TIP mode.. and im driving... and ill be doing like 50... and someone will be drving like an ass.. ill just slamm the pedal to WOT and itll jump in the third gear.. and boom ill start going fast! haha.. and then i upsift and let go of the accel and punh it back.. and i hear a little backfire.. =)
    thats all.
    but yeah first gear sucks.. slow ass balls. but 2 and 3rd are amazing.
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    you knwo what the TIP chip is a basically a little stupid
    that 200, just put it towards a trans cooler...
    my tip building technique is going to be valve body upgrade, TQ upgrade and a trans cooler. then all you Manuals can kiss out TIPPy ass. =)
    Buncha motorcycles
    Memphis, TN
    ah, you wish! you are just jealous cause she likes my "stick"
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    you know what. you have fun shifting when i dont need to shift during play..... if you get my drift.
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    Papachristou + =
    romell + =
    Buncha motorcycles
    Memphis, TN
    ah just wait till next year.... ill be mopping up you tippies!
    then it will be papa
    rommell
    Oct 22 2005
    Reppin the Mitten.
    Quote Originally Posted by romell View Post
    You could try a trans cooler, however, I've talked to a few people about it, and they don't think its feasible for you to. The transmission fluid has an optimal temperature where it works best, and by adding a cooler, yes you are making it run "cooler" but it might not be best for the tranny. I was going to go that route, until I did more research and started logging the car. I'll probably have a pretty good report of tranny temps with the GTRS kit. Btw, I don't think the tip chip would be a waste, and believe me, when I'm done testing it, you'll probably want one too. :P
    Oh and yea, i'll believe it when I see you put a GTRS in there :P, I'm sure Doug will do a good job, and sorted all out for you.
    Oct 22 2005
    Reppin the Mitten.
    Do it! BT that thang!
    Every company has quoted me different, and it has ranged from 700 to 1200 for just parts. This is just for the TQ convertor. So we'll see. I'm aiming for a higher stall tq convertor so i can launch this baby once in a while. This will easily exceed $2k, sadly...
    May 01 2008
    Winter
    I'm all the way whit you Papachristou!
    Dec 01 2008
    NM
    Quote Originally Posted by vinny.dtw View Post
    Can you elaborate more on this tip chip, and its purpose / goals? Thanks!
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    ^ haha you said it like.. you are interview someone for college.. what are your purpose and goals in life.. will you help vinny beat papa.. huh? will you?
    Veteran Member Three Rings dextrek's Avatar
    Aug 26 2008
    B7 S4
    Detroit
    Where can I find the trans cooler kit?
    -Ben-
    B7 S4 Dolphine Grey
    B6 A4 USP Moro Blue *Sold*
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by dextrek View Post
    get in the 'Zone!
    Dec 01 2008
    NM
    Quote Originally Posted by sonoflight View Post
    Feb 06 2008
    03 a4 tip
    CAL, PA
    I had my valve body upgraded and torque converter done and every body talks shit about the the ZF tiptronic but Im confident my tiptronic would hang with most manuals out there. I blew apart my torque converter on apr 1+ so with a complete rebuild and high stall torque converter it set me back 5k. The shop said that the tc is good for 700 ft lbs of torque. Plus, I need a hand free to take care of your girl. she deserves the extra attention. Ha Ha. Go TIP.
    z
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    get in the 'Zone!
    I want to see the full picture of that girl in your avatar!
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by Maverick View Post
    sorry, you cant see the rest of that one
    ill see what i can do for ya... she has some posing on my car
    Jun 23 2008
    Please keep this to the Eye Candy Forum. So let's see Papa!
    Edit- I've noticed in D around town (which is quite hilly) that when I punch the gas it's like the computer freezes and RPM's jump all over the place when on a hill. Since getting Stage 1 Revo... i'm in Tiptronic mode 99% of the time which shifts fine and more fun but just annoying when I am in D.
    Buncha motorcycles
    Memphis, TN
    i made a thread in the chatterbox... ill upload a few tonight :)
    Feb 06 2008
    03 a4 tip
    CAL, PA
    Yeah I am apr stg 1+ and in d mine is all over the place. If I am ripping on it 3-5th it will hold 21 lbs of boost with no fluctation. Its really weird. In s or tip its nice. I usually rock the s.
    z
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    21lbs?!?
    Feb 06 2008
    03 a4 tip
    CAL, PA
    psi my bad, I type too fast. Plus Im hungry for a quarter pounder.
    z
    In Limbo Four Rings
    Sep 27 2006
    New Jersey
    No I know 21 psi lbs of boost. But to hold steady at that is crazy.
