Results 1 to 40 of 77
    Jan 11 2007
    Salt Lake City, Utah
    Dynoing Wed, who want's to guess what my peak hp will be?
    Going in for a baseline dyno before I tear the car apart to put in RS6's. Mods/factors:
    -Giac XR
    -100 oct gas
    -ASP dp's
    -Apr catback
    -Test pipes
    -REALLY hard Mustang dyno
    -~4300 ft above sea level
    Any guesses?
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Senior Member Two Rings galvan11's Avatar
    Aug 20 2007
    02 pearl gt s4, vw passat, 06 cbr
    south
    Re: Dynoing Wed, who want's to guess what my peak hp will be?
    600awhp?
    Oct 14 2008
    2003 A4 1.8TQ-M, 1990 300ZX TT
    Long Beach, CA
    Not really much info there. What boost will you be running? How many miles on engine? Is your chip actually tuned for 100 octane?
    With the information you provided and that elevation I would guess somewhere in the range of 230-250awhp
    2003 Audi A4 1.8T Sport Quattro 5 Speed
    ~~VMR V710's 19x8.5 +35 * Sumitomo HTR-Z III 235/35/19 * Bilstein Struts * Neuspeed Springs * Boosted Technology CAI * GIAC Tuned * Audi TT Diverter Valve * AMS Short Shifter * 35% Tint * Clear Signals~~
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    on stock k03's most likely 280whp
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Jan 11 2007
    Quote Originally Posted by KevinZtwin View Post
    I'm guessing you don't have an S4? Just a guess because I thought it was kinda common knowledge that the GIAC XR file is the race file, tuned for race gas. Not sure the exact psi, but it usually spike to around 15-16 and taper to about 14. 56k miles, I didn't know miles had a major impact on the power (I guess compression is a pretty big deal). I'm hoping for 250whp because the dyno is really rough and the elevation sucks.
    LOOKING FOR:
    Jan 11 2007
    Quote Originally Posted by galvan11 View Post
    600awhp?
    fo sho
    LOOKING FOR:
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    i give ya 286
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    270s due to the strict dyno...
    Oct 14 2008
    Long Beach, CA
    You can only run 14psi on a 100 octane tune safely? No, I don't own an S4 (pretty obvious from my "garage"). I'm learning . What is the compression ratio? 9:1 or something? Perhaps my estimate is a little low but I was figuring the elevation was really going to sap power...idk.
    I was just guessing without doing any real research (also I do not go by what the manufacturer power gain claims...it is almost always less than the claimed gains):
    250hp stock
    GIAC @ 14psi, 100oct - +65hp
    Full exhaust - +35hp (unsure of your pipe sizes, 2.5"?)
    Health of motor? - -5hp
    Elevation - -10hp
    = 335hp - 25% powertrain loss = ~250awhp
    Again, you asked for guesses, so this is just my assumption based on my history with other cars and no history on the S4 other than my friend said they are 250hp stock. I always lean on the lesser side of things though so I don't get dissappointed. I was being generous with the powertrain loss, I would usually take 30% for AWD. IDK, be sure to post of the chart when it is all done :).
    Any time frame for completion with the RS6 turbos? My buddy has them on a 93 tune built by Wicked Motorsports but has never dyno'd, I'd like to see your numbers after the swap. He claims 450 at the crank
    Jan 11 2007
    250hp stock
    Elevation - -10hp
    Yeah, I guess I just thought the average train of thought for a B5 S4 owner to this question would be something like, "The average stage 2+ makes ~260-290whp, + a little for race gas and program, - quite a bit for tough dyno and elevation." So the actual psi ran and mileage didn't even appear in my equation, that's why I was a little taken aback I wasn't being sarcastic when I said I wouldn't be surprised if it's around 250whp.
    Timeframe for completion was supposed to be before Jan 9th, but I have a feeling it's going to be a little bit longer than that (just like everyone else's projects). I'll be running on an E85 tune from Greg at SSP, but I should be well over 450 horsepower crank. That's a safe, conservative estimate by your buddy for his setup. How is he tuned for 93 if WMS built his car (in Cali I assume?)?
    LOOKING FOR:
    Veteran Member Three Rings laxman851's Avatar
    Jan 09 2008
    2001 S4
    NC
    280whp 320wtq
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    My prediction: 289 awhp.
    We should all put $1 in a Paypal pot and the winner takes the prize.
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    700awhp and 1000tq
    and than 1000hp and 1500tq on the RS6ss ;)
    Jun 14 2007
    2000 S4
    Connecticut
    i dynoed Stage 3- on a pretty tough mustang dyno and made 286.7/336 on pump 93 with a custom VAST 3- tune. When I went back with full 3, cracked 350/405 on a disgusting day when they didn't want me to even dyno, but the trip was too much to make again.
    i would say 275 area with K03s on a tough mustang with race.
    Oct 31 2005
    Ashburn
    265WHP and 310lbs tq. That is my guess
    So what is the total parts list for your RS6 build, if you dont mind sharing?
    Last edited by highPSI-S4; 12-09-2008 at 05:05 PM. Reason: Forgot about the elevation
    - Instagram: @Sinister_rs5-
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    288whp 344torque
    Veteran Member Four Rings unknowna4's Avatar
    Oct 06 2005
    Soccer mom car
    South
    cobbs dyno?
    Aug 13 2008
    2015 Q7 P+
    279 awhp, 301 tq
    just a guess
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    i feel u on the altitude. i live at 6200ft and yes its true at this elevation i only get about 14psi out of the GIAC XR on pump and 16-14psi on race. Sea level is always a fun trip. Im excited to see the results cause that will exactly where i am at!
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    40
    SBSC
    I also like to live dangerously.
    Veteran Member Three Rings Silver streak's Avatar
    Jul 14 2007
    01 S4 stage 3 AWE full kit
    Vancouver B.C.
    295WHP - 310WTQ ?? best guess.
    attached is what my stage 2+ on race gas made
    AWE, GIAC, Stasis,KO4s, bla bla bla this is getting a bit ridiculous. I hope it will end soon.
    Oct 31 2005
    Ashburn
    ^^Are you at a high elevation as well?
    Dec 11 2006
    Boston
    271/314
    Stage 3+ RS6's
    Jul 14 2007
    Vancouver B.C.
    I'm assuming your referring to me.... I live on the coast, so I would guess sea level.
    Oct 31 2005
    Ashburn
    Quote Originally Posted by Silver streak View Post
    Yeah i was, just seeing since the OP is above sea level and runs lower boost i had to change my numbers.
    Jan 11 2007
    Look for a build log thread real soon
    Quote Originally Posted by unknowna4 View Post
    cobbs dyno?
    Yes sir. Did you dyno there or know any other S4's that have? It would be cool to compare to other Audi's on that dyno, but I'm sure there's a ton of different stage Evo and STi info I can compare it to. I know a buddy with an Evo VIII who did 'pretty much every bolt on' (not really sure exactly what was done cause he's not a good buddy or anything, but I do remember mention of cams) on with Cobb's tune I think and he dynoed like 264whp or something on that dyno. Pretty crappy reference since I don't know the specifics, but I get more info on relative cars on that dyno when I talk to them.
    LOOKING FOR:
    Oct 06 2005
    Soccer mom car
    South
    I haven't dyno'd there but I know someone thats worked there and many who have used their dyno and it's a real heartbreaker. I'd be impressed if you cracked 260whp
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    304 awhp. 353 awt
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Sounds too low for what he has, even for a mustang dyno. I'd say 275-285.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    you say really hard mustang.
    so i assume COBB's....?
    if so, 190awhp
    good luck and it will be nice to compare that for future reference. how much are they charging you? and for what. 3 pulls? or an hour rate?
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by JayyyyyC View Post
    normal mustang dyno - supercharged v8 power'd dyno
    Cobb's mustang dyno - stock v6 power'd dyno
    Current:
    Previous:
    Veteran Member Four Rings TweetsS4Estate's Avatar
    Mar 30 2008
    NYC auditioning.
    The Powertrain Loss On An S4 Is 22%!
    Quote Originally Posted by kevinztwin View Post
    you Can Only Run 14psi On A 100 Octane Tune Safely? No, I Don't Own An S4 (pretty Obvious From My "garage"). I'm Learning . What Is The Compression Ratio? 9:1 Or Something? Perhaps My Estimate Is A Little Low But I Was Figuring The Elevation Was Really Going To Sap Power...idk.
    I Was Just Guessing Without Doing Any Real Research (also I Do Not Go By What The Manufacturer Power Gain Claims...it Is Almost Always Less Than The Claimed Gains):
    250hp Stock
    Giac @ 14psi, 100oct - +65hp
    Full Exhaust - +35hp (unsure Of Your Pipe Sizes, 2.5"?)
    Health Of Motor? - -5hp
    Elevation - -10hp
    = 335hp - 25% Powertrain Loss = ~250awhp
    Again, You Asked For Guesses, So This Is Just My Assumption Based On My History With Other Cars And No History On The S4 Other Than My Friend Said They Are 250hp Stock. I Always Lean On The Lesser Side Of Things Though So I Don't Get Dissappointed. I Was Being Generous With The Powertrain Loss, I Would Usually Take 30% For Awd. Idk, Be Sure To Post Of The Chart When It Is All Done :).
    Any Time Frame For Completion With The Rs6 Turbos? My Buddy Has Them On A 93 Tune Built By Wicked Motorsports But Has Never Dyno'd, I'd Like To See Your Numbers After The Swap. He Claims 450 At The Crank
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    7elephant power. 32 meter/kgs of torque.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    267awhp, dont be upset, its a mustang dyno
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Jan 11 2007
    Quote Originally Posted by sean1.8t View Post
    if so, 190awhp
    Here you go guys, everyone one of the Utah people already knew how infamously hard this dyno is.
    Yeah, Cobbs. I just wanted to do a quick baseline pull or two, but they require a 1hr minimum, $125/hr +$20 for the wideband use. They have the only currently working AWD dyno in the area, so I guess they have a monopoly
    LOOKING FOR:
    Jun 14 2007
    2000 S4
    Connecticut
    damn, that's expensive. what time are you going ?
    Jan 11 2007
    3:00 mountain standard
    LOOKING FOR:
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by jibberjive View Post
    nice, well good luck. come flying home and post dammit.
    Jan 11 2007
    I'm actually going to be assembling a 4 post lift all night so I can yank the motor asap!
    LOOKING FOR:
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    So...whats the news? Must not be very good if you havent posted in here yet lol
    Ive heard horror stories about Cobbs dyno, and if i remember correctly it used to be $150/hr. I remember a post on an Evo forum a while back where like 40 people decided to boycot Cobbs dyno...not because of the price, but because they werent getting the big dyno numbers that they wanted lol
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
